Retainers broke off!
Old Mar 6, 2012 | 11:25 AM
500evo's Avatar
I was replacing the timing belt this morning when I turned the car on the car was knocking pretty bad. So I took out half of the engine out... What do I see 8 retainers are broken off the metal piece that holds the retainers is broken, I decide to take it in to get fixed at a local shop, I came home I see the pistons have a few hits in them from the valves. Are the pistons fine to run like this?
Old Mar 6, 2012 | 11:36 AM
todd6027's Avatar
it wasnt timed correctly, any pic of pistons
Old Mar 6, 2012 | 11:44 AM
meckert's Avatar
have the pistons checked out---a slight ding shouldnt be a problem---but the valve that hit them and the guides---well thats the real concern.
Old Mar 6, 2012 | 11:48 AM
evolutionxtac's Avatar
Sounds like the damage has already been done....bent valves.
Old Mar 6, 2012 | 11:51 AM
EvoVIIIFL's Avatar
piston hits valves.. your done.
Old Mar 6, 2012 | 01:21 PM
500evo's Avatar
The valves seem to be fine. I was just curious if the piston can work properly with few dings in them from the valves. My retainers also bent. FML can anything else go wrong here. Jesus.
Pistons have like two outlines in them. 4 of my retainers bent also. :[
Old Mar 6, 2012 | 01:46 PM
Ev0ikon's Avatar
Whoa! Sounds like you need to take it apart and bring it to a builder.
And about your dinged pistons, they should be fine. I would swirl polish the area a bit but yeah they should be fine.
Old Mar 6, 2012 | 02:00 PM
500evo's Avatar
Thank you for the help!
Old Mar 6, 2012 | 09:46 PM
IHEARTEVO8's Avatar
Did you just have cams installed??
Old Mar 6, 2012 | 10:10 PM
boostless's Avatar
if there are sharp edges in the pistons (valve imprints) you will most likely create hot spots on the pistons...not good
Old Mar 6, 2012 | 10:15 PM
mx931's Avatar
toasted
Old Mar 6, 2012 | 10:26 PM
500evo's Avatar
My car is fully stock. Should i replace the pistons if it will create hotspots?
Old Mar 6, 2012 | 11:04 PM
sujinX's Avatar
take it to a reputable shop and see what they decide. i think its better to replace everything thats damaged. u dont want to replace JUST the extreme damaged parts and later the slightly damaged part will mess up the new parts resulting in even more money.
Old Mar 7, 2012 | 12:46 AM
tsidrift1's Avatar
If the pistons have any marks on them, you better check the valves again. If they hit the pistons, they are the first thing to give. 99.9% chance they are bent. Whichever valves are bent, you better check guides too. They will crack when a valve is bent.
Old Mar 7, 2012 | 06:39 AM
barneyb's Avatar
Pistons may be okay. Valves - No.
