Overboosting Issue
Old Mar 11, 2012 | 08:12 PM
KJS's Avatar
KJS
The only thing I changed recently was a leaky BoV to a (assuming) non-leaky BoV. I kinda wanted to buy an fp green from my buddy and a 255 walbro then go to CBRD for a boost leak and a tune. But until then,
Any one have some ideas why my car overboosts so easily? Can a ****ty-*** tune cause this?
Old Mar 11, 2012 | 08:47 PM
evotuner04's Avatar
15 Year MemberLikedLoved
Originally Posted by evoBaron
have you changed anything else on the car recently? I assume you have good gas and spark plugs? just break down and learn how to tune it yourself and ECU controlled boost
still best to take it to a tuner who knows what hes doing
Old Mar 11, 2012 | 09:13 PM
adriano_917's Avatar
Make sure your wastegate is not getting stuck closed
Old Mar 12, 2012 | 08:26 AM
KJS's Avatar
KJS
How do I do that? Turn the boost all the way down and make sure it's at 12 psi?
Old Mar 12, 2012 | 01:08 PM
CBRD's Avatar
first off-
we dont like forge WG's or MBC's they have caused us problems in the past- the best MBC we have used is the hallman pro rx- but we rarely EVER tune evo's on anything other than ecu boost anymore-
to check your WG--
simply plug the nipple on your turbo intake pipe after the maf (if its not already, which it should be with an MBC)
then hook the line from your compressor outlet nipple on the turbo outlet pipe directly up to the Wastegate nipple-
that will run WG pressure-
if it doesnt then you have an overly tightened or poor WG actuator-
try that-
pm or call us with questions-
cb
Old Mar 12, 2012 | 05:17 PM
KJS's Avatar
KJS
Thanks a bunch Chad, I'll get around to it tomorrow and post you back with some results.
REVOlution X
36
Oct 16, 2012 08:59 PM
awdordie
18
May 6, 2012 07:48 AM
fit4130bmx
Feb 29, 2012 05:14 PM
shadow1
186
Sep 18, 2011 10:14 AM
MR:PartyPete
Nov 5, 2009 11:12 PM
