help!!! flywheel cash!!!
Old Mar 8, 2012 | 05:48 PM
lockadam2112's Avatar
I can't get the flywheel bolt out I've tried to heat it I've used an impact and
Use a breaker bar and still nothing if someone know something that will work ill paypal you for your knowledge
Thanks
Old Mar 8, 2012 | 05:50 PM
n2oiroc's Avatar
drill the head off of it.
Old Mar 8, 2012 | 05:54 PM
gsrboi80's Avatar
Loosening them the right way right. IIRC they are reverse thread
Old Mar 8, 2012 | 06:15 PM
Would it be bad to be missing a bolt?
Old Mar 8, 2012 | 06:17 PM
twabtoxer's Avatar
what do you missing a bolt? take some pics and post them up , might be easier for us to tell what youre seeing
There not reverse thread
Old Mar 8, 2012 | 06:32 PM
DubsE46's Avatar
Is the flywheel spinning freely? I believe you need a bracket to hold it in place.
Step #56 shows what I'm talking about
http://www.evomoto.com/tech_info.php?tech_id=27
Mine came out easy, good luck man
Old Mar 8, 2012 | 06:36 PM
hiner005's Avatar
Agree with all that. It's quick and easy. If you used an impact wrench even easier. Take a break and go back to it
Old Mar 8, 2012 | 07:02 PM
Like if I have 6 out of 7 bolts
Old Mar 8, 2012 | 07:19 PM
hiner005's Avatar
Yeah man you will want all 7 bolts...they are there for a reason.
Old Mar 8, 2012 | 07:36 PM
barneyb's Avatar
Had the same problem once. I put down the air gun, went to NAPA and bought a new one. Air wrenches loose their power with some use.
Old Mar 8, 2012 | 08:50 PM
BLK_EvIL's Avatar
take a 6 point 17mm socket and grind down flat the head about 1/8" so that the socket will make full contact with the head of the bolt since the bolts have shallow heads. You can heat the head of the bolt with a propane torch. Make a bracket to hold the flywheel in place to keep from spinning use a strip on metal drill two holes one on each end attach one end to flywheel where the clutch cover would bolt to and other end to the block useing one of the tranny bolts. That should work unless your bolts are beyond repair.
Old Mar 8, 2012 | 08:54 PM
EvoDom's Avatar
Yes you need every bolt on the fly wheel. Remember to loc-tite themm when you reinstall them.
Mine came off with a breaker bar....
Old Mar 8, 2012 | 10:45 PM
Alex.P's Avatar
Use a bigger breaker bar! I have a 1/2"x36" and a 42" breaker and it's done everything from crank bolts, axle nuts and flywheel bolts. How big is yours? Also, using a decent socket that fits snug is important too.
Old Mar 8, 2012 | 10:56 PM
boostless's Avatar
More juice on the pneumatic gun. Also, try torquing all of the bolts back in, and loosening the stuck one. When they're loosened, a lot of tension is put on the last bolt, hence having the tendency to get stuck.
One other thing...try not to "torque" the bolt off. Use sharp movements (which is why impact wrenches work the way the do)
PM me for my paypal
