Need help, want to install smaller wheels on my 8, front caliper problem ?
Old Mar 10, 2012 | 04:27 PM
04Evo851374's Avatar
Hey guys, I really could use your help. I want to install 15" wheels on my 8 with slicks and i heard that 15's will bolt right up in the rear with no problem due to the caliper is not that big and i also heard that if i go to a junk yard and purchase front stock galant rotors & calipers that they will bolt right up to the car using my own brake lines etc.
Is this true ? and if so what 15" wheels would you recommend and i don't mind using from a stock car from junk yard or so.
Please if you could help me out here.
Also what size tire then would you recommend, I see guys running very high profile drags ? isn't it better to run a lower profile tire.
Please please someone answer these for me
Thanks
Yes i know wildwood makes calipers and stuff but don't have the cash so im trying to take a short cut.
Old Mar 10, 2012 | 04:48 PM
nytalonTSi's Avatar
Why not get some FD wheels and spacers? They will clear your stock brakes, just need 20mm spacers and 2nd version of FD wheels. They have 50 marked on them.
Old Mar 10, 2012 | 05:17 PM
FD ? what are those, Do you mean stock RX7 16" wheels and what is 50 ?
Also if i install spacers on the front do i need to install them in the back as well so they match.
Im confused as you can see that i have no clue
Old Mar 10, 2012 | 05:20 PM
I like what your saying 16's then i don't have to swap rotors etc i like that much better. Thank you
Now help me out with that question 20mm spacers for the front what about the rear? and again what is that 50 that you wrote.
Thanks again
Old Mar 10, 2012 | 06:37 PM
barneyb's Avatar
https://www.evolutionm.net/forums/ev...15-wheels.html
senate6268
206
Jul 14, 2024 07:20 AM
Green_Bandit
21
Sep 9, 2019 02:14 PM
JRitt@essex
Sep 2, 2014 10:09 AM
Mellon Racing
EvoX 'For Sale' Suspension / Brakes / Handling
394
May 24, 2013 05:48 PM
SparkTech
26
Dec 9, 2011 09:10 AM
