lower ball joint
Old Mar 10, 2012 | 04:55 AM
EVO4marky's Avatar
lower ball joint
does a evo 4 1996 reg lower ball joint come away from the arm or is it all in one pice just fail mot and need 2 get sorted.plz help
Old Mar 10, 2012 | 08:44 PM
ProPilot04's Avatar
There were 2 types of LBJs used on the 5th gen Evos. Some had a balljoint that was part of the arm, and some had a removable ball joint.
I believe the part number for the REMOVABLE ball joint is MR485675. Do you have a picture of your A arm? I can probably tell you if it will be removable if I can see the assembly that you have.
If I had to put money on it, you more than likely have the non removable type. This was one of the changes that they made to the E6 TME I believe (all removable) compared to some E4/5/6's coming with part A, and some coming with part B.
It's been a while though... so don't quote me on any of this.
Old Mar 10, 2012 | 08:45 PM
ProPilot04's Avatar
I just found a pic.
This is the type with the removable LBJ.
Jonno99
Sep 12, 2016 03:35 PM
evopowered8g
Jul 8, 2014 08:07 PM
a4rontran
May 13, 2013 07:56 AM
DisgustipatedM3
Oct 22, 2012 05:40 PM
lucky_evo
12
Jan 17, 2010 07:23 PM
