Control Arm / Ball Joint ??
Old Dec 29, 2009 | 05:05 PM
lucky_evo's Avatar
So I was told by our local Hibdon's that the ball joint has to be replaced along with the control arm... and after they struck out twice i'm to fend for myself on finding a replacement ....... does anybody know where I can find a front right lower control arm / ball joint ??
Old Dec 29, 2009 | 05:10 PM
ak47po's Avatar
Ask RussellM.
https://www.evolutionm.net/forums/mi...ts-net-wa-238/
Old Dec 30, 2009 | 10:00 PM
huevosrancheros's Avatar
THe control arm does not need to be replaced(unless you ran over a fire hydrant). Get yourself some white line balljoints and get those badboys pressed in. If not just get some used control arms off of somebody from here on evom.net
Old Dec 30, 2009 | 10:12 PM
wickdaddy's Avatar
+1 on this. Just had my joints replaced with the Whiteline Front Roll Center Adjustment Kit just prior to rolling 100k.
Purchased mine from MAPerformance and had Buschur install. Make sure to get the car aligned after
here's the link to the kit: http://www.maperformance.com/whiteli...t-kit-evo.html
Old Dec 30, 2009 | 10:26 PM
compscibOi's Avatar
Doing the same thing to my Evo. Whiteline ball joints and the steering precision kit. Then an alignment.
Don't replace using OEM parts when aftermarket can do better.
Old Dec 30, 2009 | 10:27 PM
I have mine set up to go put need some money to get them pressed in at modified. I also bought the energy suspension control arm bushings(pillowmount and control arm bushing fro the front pair for
Old Dec 31, 2009 | 05:59 AM
EvoPooPoo's Avatar
I don't think mitsu sells just the ball joint, reason why they tell you to get a new arm.
I went through the same thing.
I bought Roll center adj kit through Touge Factory and had it installed and aligned by them.
No need to get expensive oem stuff.
Old Dec 31, 2009 | 06:51 PM
lucky_evo's Avatar
sounds like that's the route I'm going to take.. have both sides done.. instead of control arm and balljoint for 360 from dealership..
Thanks Guys ! !!
Old Jan 3, 2010 | 09:04 PM
biggie5252's Avatar
I've found that if you bring in just the arms to have bushing pressed out/in a lot of places will do it very cheaply or free (I ended up giving a guy at firestone a case of beer) cuz they didn't have just pressing bushings as a chargeable item in their computer. Sears pressed out the stock bushings for my rear bump steer kit for free for the same reason.
Old Jan 3, 2010 | 09:10 PM
lucky_evo's Avatar
good to know[B]
Old Jan 5, 2010 | 12:26 PM
wickdaddy's Avatar
nice work firestone said they were going to charge me haha
Old Jan 15, 2010 | 05:02 PM
lucky_evo's Avatar
so now I'm being told while they were trying to replace my control arm that a bolt going in to the body has busted loose and I'll have to cut a hole a body panel to access the nut to remove the control arm ? anybody know if this is true or not, if so what would be the best procedure to get this done ? I need to get this fixed ASAP so please hit me with some knowledge.......... THANKS ! !
Old Jan 17, 2010 | 07:23 PM
lucky_evo's Avatar
........... nevermind.. got it fixed....................
Killboy
75
Jun 18, 2014 12:18 AM
SilentCool
Dec 22, 2013 02:11 AM
jwick76
Jul 27, 2011 08:48 AM
AutoXer
Jun 9, 2010 03:47 PM
TS8
Jun 1, 2010 05:42 PM
