Vortex roof wing
Its a generator, not a wing.
If you can somehow get a piece of dental floss in-between the roof and the generator, that will be your ticket. Look up videos of de-badging, same concept.
no, you have to open the trunk. Then on both sides ( leading from the vortex generator down to the trunk ) there are skinny lines, you have to take a flathead screwdriver, and kind of pop out the lines, going all of the way up until you get to the vortex generator....
If you still dont understand which you probably wont, post here, and i will make you pictures or a video
Search is your friend...
http://www.youtube.com/watch?v=HHT9Y...layer_embedded
Basically follow his tutorial but when you get the weather stripping off take a heat gun or blow dryer and heat up the generator. Once you've done enough you can start to pull it off, and you also could use fishing line to make it easier.
Follow the video, unclip the weather stripping on both sides, if you have one on there already you will need some fishing line and a heatgun/ blow dryer to heat up the old one to peel it off. Yes it is double-sided tape but it shouldn't come off easy if it was installed correctly. Once that's off use alcohol to clean the surface, stick the new VG in place. Then put the weather stripping back on top of the wing to hold it down. Done.
george3
Nov 21, 2015 05:48 AM
LukePilot152
Aug 28, 2015 09:07 PM
