3 fuel pumps! WHAT!!
Old Mar 12, 2012 | 04:38 PM
vinnieg's Avatar
i currently have 3 fuel pumps in my evo and its killing on gas especially with stock injectors the guy before me did this............ how hard do you think it would be to go to a single wabro with fic 1250cc injectors i have a fuel rail and a fuel regulator already just need to get injectors...
Old Mar 12, 2012 | 04:43 PM
EvoJoeIX's Avatar
3 fuel pumps with stock injectors?
Is this real life?
Old Mar 12, 2012 | 04:46 PM
sujinX's Avatar
im guessing it depends on how the 3 pumps are setup.
Old Mar 12, 2012 | 04:48 PM
vinnieg's Avatar
i believe i have a picture of my fuel pump, ill show you the guy before me took his turbo injectors only god knows what else lol
Old Mar 12, 2012 | 04:49 PM
vinnieg's Avatar
Old Mar 12, 2012 | 05:25 PM
Kevin Knight's Avatar
y do u have 3 pumps again?
Old Mar 12, 2012 | 05:43 PM
SFL Autosports's Avatar
Just because you have 3 pumps doesn't necessarily mean you are going to waste more gas.
Old Mar 12, 2012 | 05:49 PM
SDevo13's Avatar
I have 4 O.o and your pumps don't dictate gas mileage. How much fuel your injectors dump does. You could have 15 pumps and get the same gas mileage.
EvoJoeIX's Avatar
Why does your sig say you have a double pumper, but your saying you have 3 pumps?
SmurfZilla's Avatar
THis is a joke right? 3 pumps and STOCK injectors. WHy on earth would anyone need 3 injectors?
Old Mar 12, 2012 | 05:58 PM
wizzo 8's Avatar
Thats crazy! Get a picture of the assembly when its out.
Old Mar 12, 2012 | 06:05 PM
gpfury86's Avatar
3 injectors is this a new speed secret? lol The op has stated the previous owner had a bigger turbo and injectors and took them off and just left the fuel pump setup. Im guessing it has a double pumper with an inline pump, but why? Also it's not getting bad gas mileage cause of the fuel pump setup, its probably runnin too rich and u probably need to turn the IDC's down
Old Mar 12, 2012 | 06:24 PM
vinnieg's Avatar
why there is 3 pumps i have no idea im just stating the facts.. if it wont make any difference then ill just leave them and just get the injectors
Old Mar 12, 2012 | 06:31 PM
GTijoejoe's Avatar
You still only have 4 injectors using it
Old Mar 12, 2012 | 06:38 PM
sujinX's Avatar
the pumps supply the fuel pressure, the injector duty in the tune dictates how much is being injected in your combustion chamber. at least u dont have to worry about the pump not supplying enough pressure. and if 1 goes u still have 2 more... jk
but it you want to switch back, u have to figure out the wiring and if there is an inline pump. your going to need a stock sending unit.
