how good is the stock pcv
Old Mar 17, 2012 | 01:15 AM
Underated's Avatar
im putting together a catch can setup. i read the pressure issue thread already but didnt see anything about the pcv. im trying to decide if i should keep the pcv or ditch it and cap off the intake manifold.
if the stock pcv isnt rock solid then it makes no sense to use it... so is there an upgraded check vale that i can put in its place.
Old Mar 17, 2012 | 01:39 AM
anthonyrb98's Avatar
are you planning to use a vented catch can? if so, then you can ditch the pcv. the stock pcv is pretty reliable, but if you plan on recircing back to the intake manifold, then I would run another check valve between the catch can and intake manifold. kynar check valves work well.
Old Mar 21, 2012 | 08:04 AM
barneyb's Avatar
With plenty of miles on my car, I thought it was time to replace my pcv valve. I picked up a new one from Advance Auto only to find I could blow through it both ways - took it back for a refund and replaced the stocker which was working fine.
him
Lancer Engine Tech
May 3, 2019 11:32 AM
aamoedo
Oct 28, 2016 09:22 AM
Junkyardspecial
Sep 17, 2015 03:18 PM
LakerRaider
Mar 27, 2011 06:40 PM
Svendiesel
Dec 15, 2010 08:13 PM
