running lean at idle
Old Jan 27, 2017 | 03:13 PM
kaj's Avatar
kaj
Originally Posted by Ragin-Azn
Well now i gotta cel and no afr reading at idle lol. Cars idles smooth no issues still pulled my buddies 350whp sti so its runnin fine lol. Could it be a bad o2 sensor?
Originally Posted by Laddy07
Ok I have a 2012 evo x .. just got tuned and has a rough start and idle running 14.5 then dropping to 18 and stays there for a bit to eventually make its way back up .. I also feel there is a loss in power. things I've done to try to fix the problem include :
New upgraded fuel pump and fuel line
Upgraded 1100 Id fuel injectors
Smoke test for leaks -- a leak in intercooler and leak is fixed
Freshly tuned
Codes : misfire in cylinder 4
My coils and sparks are fairly new ..can they really fault that fast
Could this be the reason she is running lean ? And idle bring all over the place .. please help
Is it only at idle? Does the idle change when you roll windows up, turn on AC/defroster, etc?
Old Nov 7, 2022 | 12:17 PM
joshua proulx's Avatar
i have the exact same problem, idle is 14.7 then shoots up to 17 and idles bad, rough start sometimes… no codes though but my idle change when I use my windows. Wot is 10-11
Evo x 2008
Old Nov 7, 2022 | 03:03 PM
kaj's Avatar
kaj
Evo x 2008
Do you have a mini battery?
Old Nov 7, 2022 | 06:23 PM
i don’t understand, are you trying to ask if my battery is small? No it’s a deep cell battery off a boat lol works perfectly in winter. How does this effect idle?
Old Nov 7, 2022 | 08:33 PM
kaj's Avatar
kaj
My car had a few of the the same symptoms, for example running weird when I would roll the windows up and down. My theory was that my mini battery couldn't handle it. Especially shortly after the car started and it's partly drained. I went back to a standard size battery, and have not had the same problem since.. I tend to throw weird ideas out there, cuz there's the ones that tend to get me. It's never the common s*** LOL
Old Nov 8, 2022 | 08:53 AM
Biggiesacks's Avatar
what's the state of charge on the battery when this is happening?
If you charge the battery up fully, then operate the vehicle, does the problem persist?
wrinkly
Sep 5, 2017 05:40 PM
Evo47
Jan 3, 2017 06:43 AM
papabeardoe
Jun 12, 2016 03:27 PM
12WWGSR91
Nov 10, 2013 12:12 PM
TurbosamVIII
Apr 10, 2013 08:56 PM
