Fp black on stock block set up
Old Apr 6, 2012 | 11:57 AM
stck_trbo_mnstr's Avatar
Originally Posted by steelfire19
I have fp black on stock block gsc s2 and all other basic bolt one's, been running it for about 5k miles with no issues. As long as you keep the TQ low you will be fine, but to get the full effect of the black I'd say build the block in your off time which is what I am gonna do. But with the driving you do I'd say you will be fine. Good luck!
How much power r u making ?
Old Apr 6, 2012 | 10:32 PM
uhhhson's Avatar
I'm at 406 whp on a mustang dyno, stock block with a black and I'm not stressing, it comes down to setups and tunes, you have blown motors from knock, detonation, and not proper cooling, I dd my car and don't race it though, high power on pump gas is not all that safe though go e85 or 110 and go big when it pops, I have only 30k miles on my 03 and the motor is solid
Old Apr 7, 2012 | 07:52 AM
fabcas311's Avatar
mine went kaboom after 500 miles..........but i was beating the car when i had the HKS turbo 30 passes on the drag strip and WOT almost everyday!lol....
i made 506/447
Old Apr 7, 2012 | 09:04 AM
SPATT's Avatar
Originally Posted by metalsaber
Had stock block and fp black on pump gas. Engine popped. Would never do it again.
how conservative was the tune?
Old Apr 7, 2012 | 12:15 PM
metalsaber's Avatar
Conservative. Definitely no where near the edge. Was only running 26ish lbs of boost.
Old Apr 7, 2012 | 01:53 PM
gpfury86's Avatar
Ive heard of people runnin 550/470 on stock blocks and no problems, then I've seen people with 470/420 pop in no time. It's an engine with mechanical moving parts no tellin when or why something fails, but it happens. Putting good parts in it and assembling it correctly is the best way to ensure the most secure reliability and even then stuff can fail when assembled properly. It's all in good fun though.... Too make boost!
Old Apr 7, 2012 | 01:59 PM
binky's Avatar
I would leave the power where it is.
My stock block survived at 440 WHP (Dyno Dynamics) for a while but, after a few weeks the #2 cylinder began to loose compression.
If you want more power, do it right and build the motor. In the end it won't be cheap, but it will be cheaper than also having to buy a block to use as a core.
I built my motor and haven't looked back. I am now at 466 WHP on a Mustang Dyno (520 WHP Dynojet).
If you need ideas, check out my build thread in my sig.
-Bink
Old Apr 7, 2012 | 06:36 PM
metalsaber's Avatar
That's really the big mystery. I've see a local guy running a FP Green making great torque and been running for a few years now with lots of major events under his belt. No issues.
That's why I say to build the bottom end if you can. It's cheaper to do it before it blows.
Old Apr 10, 2012 | 03:51 PM
JiNSOO619's Avatar
It really depends on the tuner as well. You can have a tuner who tuned your car to 400ft-lbs and run like crap w/ high knock counts and end up making it blow. And others will make it run as smooth as butter from 0-2 knock counts. I'm pushing 465whp/355ft-lbs@30psi, 1 knock count is the highest I got @ 7,400rpm on stock cams.
Thinking of going getting GSC S2 cams as well, shoot for 500whp/380-400ft-lbs, and I'll be happy with that.
Old Apr 10, 2012 | 04:23 PM
jayg4u's Avatar
Veteran: Air Force
Just build your block and save yourself the pain of siting on the side of the road.
Old Apr 10, 2012 | 07:07 PM
sublime44's Avatar
This is what happened to my motor. FP Red 29psi on E85. VD numbers were 504/468, destroyed EVERYTHING. By everything I mean tcase, radiator, the entire head, EVERYTHING.
Thats looking straight through the block
There were 9 holes total in the oil pan
Old Apr 10, 2012 | 07:18 PM
binky's Avatar
Wow. That's impressive damage
I'm sure you were really happy to see that....
-Bink
Old Apr 10, 2012 | 07:32 PM
420a-t's Avatar
I was 506 awhp/477wtq on my hta green setup on 33 psi, and I am now on my fp black with 34psi. Ran for a year with both setups (on e85). Still running and I drive the car about 3-4 times to and from work and on weekends.
Old Apr 10, 2012 | 07:48 PM
sublime44's Avatar
-Bink
What really pisses me off is I was only going about 35mph maybe 1/4 throttle and it blew when I shifted into 4th while I was going to the store to get beer. Ive seen quite a few people on here with 05 Evos where the #2 rod snapped while driving normal.
Old Apr 10, 2012 | 07:58 PM
Blue91lx's Avatar
Originally Posted by stck_trbo_mnstr
i dont race the car. every once in a blue moon ill get on it, but i am not one to run it hard every day, usually cruz between 2.5-3.5k rpm.
What's the point?
