why does my evo vi max out in 188-190 kmph??
dear pro members. i recently bought my self an Evo VI CP9A,
look wise its sexy n all.. but when it comes to top speed, my car max out in 190kmph & rev up to 7300 in 5th gear to achieve it..
. please can somebody help me with this.. its runnig stock ecu
Apexi avcr (put 0.9 bar boost duty 50% to check the top speed.)
3" exhaust piping
K&n cone air filter..
please help..
no mate.. suddenly it gives a small sound and speed reducers... so i put it 2 neutral... and put to 4th gear & did 100. (tried this twice, first time did 189 & second tym also problem hapend at 188.. (avcr readings). does this problem got to do with e avcr:?
and mate thanks for the quick response
Jap spec evo VI?? if it is then you have hit the limiter.. you need to get evoscan and flash the comp to get rid of it... It should be floor it then engine will cut or seem like its dead, if you keep the foot to the floor it will arc up again once your speed reduces to about 170 or so...
All Jap spec evos are limited to 190kmh
< Doesn't know RS ratios.
So you have an RS?
If you are hitting the rev limiter in top gear you have two options to increase your top speed.
1. Increase your rev limiter. This isn't really recommended, you'd have to modify certain parts of your engine to make it capable of withstanding higher RPM and the gains wouldn't be very much at all.
2. Look at your options to modify your drivetrain (I don't know enough about ratios with transmissions and differentials to advise any further).
wait.. im not sure whter i revd 7300 in the 4th gear.. and in the 5th maxed out at 189kmph around 5000?? i'l do another test drive and let you know exactly what the ratios are.. and people, this might sound stupid.. but can anybody tell me the differnece between
Evo VI
Evo VI RS
& Evo VI GSR ?? and which is better??
Evo VI
Evo VI RS
Evo VI is a blanket term for that whole generation of evos.
GSR is the regular street trim evo. RS is the evo with non essentials removed, power windows, expensive seats, airbags etc. RS was intended for race car builders to buy and not have to pay for a whole lot of parts that they weren't going to keep anyway. RS2 is an RS with a few features from the GSR added, sort of midway between the two models.
Do you have manual or electric windows? If you have manual windows you have an RS.
If you have electric, do you have TD05RA-15GK2 or TD05HRA-16G6 turbo? (Turbo will have a stamp on it).
The 15G is from the GSR, the 16G is the RS2.
Edit: Turbo specs are wrong. GSR is TD05HR-16G6-10.5T. RS/RS2 is TD05HRA-16G6-10.5T. Difference is the A indicates a different turbine wheel.
for some reason i think your running out of gear, or speed limiter or both.
i dont know anything about those drivetrains, but you can get a lower final drive or get a lower 5th gear. (if available)
.. yup.its a JDM Evo
I see what you did there.
