Boost gauge mounting idea
Old Jan 21, 2004 | 07:18 PM
BenM's Avatar
hey, just a quick wonder.... do you think it would be possible to mount a boost gauge where it says lancer in the gauge cluster?
Ben
Old Jan 21, 2004 | 07:49 PM
OnlineAlias's Avatar
Re: Boost gauge mounting idea
Ben
That's where should have put it. I have been hesitant to break mine open and give it a whirl tho....
Old Jan 21, 2004 | 07:53 PM
Bom's Evo's Avatar
anthing is possible. it depends on how much clearance u have back there. you just need to take a look to see if theres a way to cut into there.
goodluck
Old Jan 21, 2004 | 07:56 PM
kuniboy's Avatar
naah.... had that idea before. Not enough clearence.
Old Jan 21, 2004 | 07:57 PM
MalibuJack's Avatar
Anything is possible with electronic gauges.. I'd be brave enough to try it if I had a spare cluster.. LOL
Old Jan 21, 2004 | 08:01 PM
evoego's Avatar
Registered User
thats exactly what should be there from the factory.
Old Jan 21, 2004 | 09:34 PM
BenM's Avatar
i agree.... if i had a spare cluster i'd try it too... i guess behind the gauge faces there would have to be circuit boards and plastic casing for the electronics and what not... prolly not enough room. ah well, it was worth asking.
Thanks guys
Ben
Old Jan 21, 2004 | 09:40 PM
Serge03's Avatar
go to a bone yard and practice what you want to do on a wrecked car cluster- it will be a less painful mistake that way!
Old Jan 22, 2004 | 07:09 AM
webguy330i's Avatar
You'd have to find a guage to fit that area, or "bore" it out so to speak. I think it's only like 45mm or something. That's where I want to mount a gauge.
Old Jan 22, 2004 | 12:27 PM
BenM's Avatar
i don't think i'd be able to cut it out. i just figured that the piece that says "lancer" would just pop out from the back when you opened up the cluster. someone said that it was a 45 mm hole? are there any gauges that are 45mm? what is the standard size for a gauge?
Ben
Old Jan 24, 2004 | 10:02 AM
Boosted's Avatar
52mm or 60mm
Old Jan 24, 2004 | 10:17 AM
NYEVO8's Avatar
Ben
i think omori makes a 45 mm gauge.
Old Jan 24, 2004 | 11:17 AM
LDB's Avatar
LDB
Like everyone else I want to know why Mitsu didn't put a boost gauge there to begin with. Maybe they think nobody is interested in a boost gauge in their Evo... YEAH, RIGHT!
Old Jan 25, 2004 | 06:56 PM
YellwTyper's Avatar
Doesnt HKS make very thin gauges? Couldnt you just fit it on there and most likely look ok?
