Valve Cover HELP ASAP
Old Apr 7, 2012 | 07:50 PM
Montreal's Avatar
Hello everyone Im new to this site and need help with my Lancer ES 2.0. Ok so today i painted my valve covers and took them off just fine, but now that i put them back on and hooked everything back up its making weird noises and the motor is now shaking and scaring the hell out of me. I think I might have made the bolts too tight but I really dont know and I didnt go in any real order.
Should I take it off and try again?
or loosen It?
ideas?
Old Apr 7, 2012 | 07:58 PM
wizzo 8's Avatar
The valve cover wouldn't cause anything like that. A loose connection would
Old Apr 7, 2012 | 08:32 PM
STIKiller4G63's Avatar
I would lookk for loose connection or a vacum leak
Old Apr 7, 2012 | 11:26 PM
3K's Avatar
3K
Check the plug wires, they're probably in the wrong order.
Old Apr 8, 2012 | 01:14 AM
ch53avitech's Avatar
I have the strange feeling we're being trolled, but to answer your question, no way will/can the valve cover cause your motor to shake.
Is this your first car?
Old Apr 8, 2012 | 02:37 AM
Montreal's Avatar
Nah I'm not a troll bro and no its not my first car but I am young and still learning things. but what order does the connection go in 3K?
Old Apr 8, 2012 | 05:39 AM
mt057's Avatar
Did you have the valve cover sand blasted before painting?
Are you throwing any codes?
Just noticed this is in the wrong section....
Old Apr 8, 2012 | 07:47 AM
MyEvo8Urs's Avatar
Sounds like Vacuum Leak or spark issue. Leaning more towards spark if its shaking.
Old Apr 8, 2012 | 12:54 PM
Montreal's Avatar
Thanks everyone!
After I did some research I found out it was firing order, I put it in completely wrong. Thanks to an old pic I had of it before I changed it, I was able to get it right back normal, thanks again.
Old Apr 9, 2012 | 04:50 AM
EvoRuss's Avatar
