Help with my front end Clunking/Popping noise
Old Apr 8, 2012 | 02:46 PM
bpmx959's Avatar
What up guys.
Searched regarding my question but didnt find the answer im looking for.
When im coming to a stop around 10 mph the front end of my car makes a clunk or pop noise, then when i disengage my clutch to take off(even smoothly and slowly) it makes the same noise again. It does this all the time and im sick of it. I want to say tie rod ends but they look fine. Im rockin tein coilovers, and im not super low at all. Anyone have the same issue??
Old Apr 8, 2012 | 02:49 PM
thedru13's Avatar
Check your sway bar bushings make sure they have good amount of grease on them. is the noise front or rear?
Old Apr 8, 2012 | 02:54 PM
bpmx959's Avatar
I will check them. The noise is coming from the front, sorry.
Old Apr 8, 2012 | 02:57 PM
thedru13's Avatar
I would check your end links and all suspension related parts. Do you feel anything? Going to assume that the car is driving fine...
Old Apr 8, 2012 | 05:05 PM
bigben's Avatar
Mine started doing this, but the driver side outer tie rod end is the cause of mine. If the rubber boot on it is torn, then it might be the culprit.
Old Apr 9, 2012 | 11:45 AM
SPATT's Avatar
Tierod or lower ball joint would be where I would start looking.
Old Apr 10, 2012 | 10:27 AM
tsi90awd's Avatar
I had a clunk that was hard to diagnose. Turned out that the nut that tightens the damper shaft on to the strut bearing on my Ohlins coilover was loose.
Old Apr 10, 2012 | 10:34 AM
jmarsh2405's Avatar
I work at anderson ford and fords are bad about clunking noises in the front end. It could be many things. I would start by looking at the sway bar end links. You can check by wiggling them when on a lift or take them loose and try to enduce the condition where they usually pop. If it doesnt happen then at that point it would probably be the end links. Also my evo used to pop when going over bumps at times or when disengaugeing the clutch and it ended up being my lf top coil over bolt as tsi90awd said. But thats where i would start. try that and let us know what happens. Good luck.
Old Apr 10, 2012 | 01:12 PM
CoolSkool's Avatar
My Rx8 had a clunking sound coming from the front end and i swore it was the suspension it turned out it was the exhaust that got loose and just making contact ever time i would stop and accelerate. This is probably not going to be your issue but just an FYI, to look even where you don't expect it.
Old Oct 2, 2012 | 09:14 AM
elim0's Avatar
sorry to bring back an old thread OP but ive posted / seen a number of these threads with no definite answers. your problem sounds similar to mine, i was wondering if you ever found out a solution to the noise ?
Thanks
Old Oct 2, 2012 | 09:42 AM
dastallion951's Avatar
It would be either a worn ball joint which usually clunks when turning. Of a bad tie rod end. Or check your upper strut mounts for cracks and movement. Gl.
Old Oct 2, 2012 | 02:29 PM
thepoint4life23's Avatar
Yea i go with bad Ball joints. or sway bar end links.
Old Oct 2, 2012 | 07:51 PM
DropThatHammer's Avatar
Bump for an answer
Old Oct 2, 2012 | 08:04 PM
EV0L-IX-MR's Avatar
This thread helped me. https://www.evolutionm.net/forums/ev...end-noise.html
Old Oct 3, 2012 | 05:33 AM
crazybaldhead's Avatar
man...I changed all bushings, spring insulator, inner outer steering ends. Still makes the noise.
i've started turning up the radio.
