Trigger plate wobble?
Old Apr 15, 2012 | 01:26 PM
xRoguex's Avatar
http://s24.photobucket.com/albums/c3...-00-48_152.mp4
Is this ... normal?
Old Apr 15, 2012 | 01:45 PM
CurseDSM's Avatar
Take it out Will I wanna see what the bolt and the inside of the trigger looks like. I am sure its mangled for sure.
Old Apr 15, 2012 | 03:01 PM
EvoJoeIX's Avatar
Not normal
Old Apr 15, 2012 | 04:18 PM
xRoguex's Avatar
I should also note -- that is with the bolt TORQUED TO SPEC..
Old Apr 15, 2012 | 05:36 PM
Solenoid's Avatar
Veteran: Marine Corps
How exactly did you find this problem? What were the symptoms?
Never seen what was inside the valve timing component until your vid
Old Apr 15, 2012 | 07:44 PM
CurseDSM's Avatar
My guess is car didn't want to start for whatever reason and when it did it didn't seem right. And with further investigation of the problem he found that.
Old Apr 15, 2012 | 08:58 PM
xRoguex's Avatar
It died at a light. And refused to start. crank and cam sensor codes came up..
they both dont die at the same time...
pulled the plate off and saw that... wtf...
