Radiator Fan always on ??
Old May 21, 2012 | 01:06 PM
EvoIIIAj's Avatar
I have this problem also. Haven't found a fix yet..
Old May 21, 2012 | 07:19 PM
AJCaron12's Avatar
To all the people that said thermostat... how could the thermostat be the problem if the fans come on right when the key is on? What is it, an electrical thermostat?? You have an electrical problem. I've seen bad coolant temp sensors do this. The fan is always on because there is an electrical problem somewhere, and the fan is staying on as a failsafe since it does not know what temp to come on at, so it just stays on, to prevent overheating. Just like when certain modules go bad sometimes, the wipers and headlights will stay on for example, as failsafes for the car, as if you were driving in the rain, or if it were dark at night.
Old May 21, 2012 | 07:22 PM
AJCaron12's Avatar
Originally Posted by TURBO_S2K
UPDATE!!
Like I said before, the fan switch and the fan module are fine
When I remove the relay from the fusebox, the fans stop
So after I removed the relay, I checked the female side (the part that is on the fusebox where the relay is plugged into), and it is getting a consistent ground
How can a grounding kit fix this?? As far as I know, the grounding kit connects to the + and - on the battery and the other grounds connect to the engine block, fuel rail and intake manifold...
Dude, the fan needs a ground for it to work, that's normal.
Old May 21, 2012 | 10:52 PM
Blitz_b9's Avatar
mine also have the same problem., i think it got do with e ECU, but in mine i have a seperate button to turn it off...
Old May 21, 2012 | 10:54 PM
Blitz_b9's Avatar
but i was advised to get the Thermostat checked..
Old May 24, 2012 | 09:42 PM
AJCaron12's Avatar
Ok.... did you?
Old May 24, 2012 | 09:52 PM
Blitz_b9's Avatar
Originally Posted by AJCaron12
Ok.... did you?
no. but i have a secondary button fixed, to switch it off..
Old May 24, 2012 | 09:54 PM
Blitz_b9's Avatar
my car has been track used. so had an ecu installed so according to the previous owner, changing back the stock ecu caused the problem.. not soo sure which one to believe.. guess its an easy fix..
Old Jul 8, 2012 | 11:53 AM
ablan029's Avatar
before i start replacing my temp sensor or fan control module, has anyone found a fix for this yet??
Old Jul 8, 2012 | 12:02 PM
evobros's Avatar
+1^
Old Jul 8, 2012 | 01:53 PM
ToddRhodes's Avatar
Probably not the same in an EVO but i has this issue in my 2G DSM and it turned out to be a blown driver or something to that effect in the ECU. Tom at ECMTuning fixed it for me. No idea who can do that for EVO ECUs though.
Old Jul 8, 2012 | 04:47 PM
ablan029's Avatar
so, the general consensus seems to be that the ECU is messin up here?? is it something with the hardware or is it the programming?? i'm gonna have my ECU reflashed this week at AMS so hopefully they can shed some light.
Old Jul 8, 2012 | 08:09 PM
Tekniq's Avatar
+1 Your coolant temp sensor is bad.
Old Jul 16, 2012 | 05:06 PM
EvoIIIAj's Avatar
Mine was the fan control module. Installed a new one last week. Problem fixed for me.
Old Jan 24, 2017 | 01:56 PM
Zin740's Avatar
FrankMc hit the nail on the head
