Weird problem~~?
Old Apr 22, 2012 | 10:42 AM
germanmike954's Avatar
Weird problem~~?
i just recently put together my 2006 gsr, car was in a accident and we pulled the motor out. Ok so the problem im having is that if you start the car it runns perfectly fine and is drivable aswell, no check engine lights at all, but once you get on it stock ecu is randomly picking up .9 counts of knock and retards the timing to -1 degrees causing the car to start popping and backfiring. we have changed pretty much every sensor, replaced ecus, replaced engine wiring harness. Im puzzeld as to why its doing this. At awd chris speed hooked up a haltech and the problem went away.. im lost lol. any body know as to why its doing this, the stock ecu even read knock when the sensor was unplugged or turned off in the ecu.
Old Apr 22, 2012 | 10:43 AM
could the mived be causing this/?
Old Apr 22, 2012 | 08:17 PM
damn nobody have any suggestion?
Old Apr 22, 2012 | 09:39 PM
Anarchy99's Avatar
It has no knock sensor connection
Old Apr 22, 2012 | 10:21 PM
that would make it pull timing/?
Old Apr 23, 2012 | 10:23 AM
impact blue's Avatar
Either that or you neou ed a tune up from using a lower octane rating of 93. I also think the sensor is bad or does not have a good connection. When knock sensors go bad they tend to jack with the timing alot because the computer is trying to compensate for the signal its not recieving so it backs the timing down to prevent you from blowing up the motor to some degree. I would get it double checked and report back.
tunermt
AEM EMS
24
Dec 13, 2025 01:26 AM
tweakdsm
Mar 31, 2010 03:06 PM
taenaive
Nov 1, 2009 08:56 PM
HiVoltEVO8
49
May 11, 2006 11:50 AM
silverEVO8
43
Apr 17, 2005 09:42 PM
