Knock at idle?
Old Mar 28, 2010 | 08:23 AM
tweakdsm's Avatar
Knock at idle?
After the build car ran great, after 1k miles, air fuel changed to 10 at wot. We adjusted the map pulled the timing by 2 deg and lower the boost to 20. Just to be safe. 3rd and 4th gear no knock at wot. When the car idles and if i you tap the gas pedal, knock shows 10 - 15 counts. Or if I drive 45mph and hit the gas to the floor on fift gear, Thers knock.... any ideas? I'm thinking to replace knock sensor , boost leak was done. Compression shows 180 across the board. Maf changed even ecu was replaced, just to check. No sound from the engine at idle and rev. Wide band replaced. I have 105k miles on the body and 4k on rebuilt. Mods are in my garage. Thanks, any input will be greatly appriciated
Old Mar 28, 2010 | 01:27 PM
tweakdsm's Avatar
bump
Old Mar 28, 2010 | 04:26 PM
LCS's Avatar
LCS
False knock? If so, that's a knew issue.
Old Mar 30, 2010 | 09:49 AM
tweakdsm's Avatar
fixed.
Old Mar 31, 2010 | 03:06 PM
jcroswell's Avatar
What did you do to fix the issue?
03GS-T
Oct 23, 2016 09:55 PM
740 Turbo Brick
Aug 24, 2016 11:44 AM
hattackk
Nov 18, 2015 06:15 AM
vroomevo
Apr 27, 2007 12:44 PM
smokedmustang
23
May 9, 2006 09:40 AM
