Diverter valve & v band ic pipe help.
Old Apr 26, 2012 | 11:09 PM
Graphic's Avatar
I have a synapse diverter valve. How will I know if this is going to be strong enough for my build?
Specs are in my sig, I plan on runing 92 70% of the time and E85 30%.
Is there a place I can get a 2" vband pip?
Old Apr 27, 2012 | 05:41 AM
GTijoejoe's Avatar
What do you mean strong enough? Hold enough PSI?.... you won't be able to run enough boost to leak a synapse valve..... having enough flow could be a concern... but I doubt it.
Old Apr 27, 2012 | 07:09 AM
Thore's Avatar
I'd swap the worm clamps for t clamps, especially that rusted *** one in front. If you are worried, I mean.
Old Apr 27, 2012 | 10:00 AM
Graphic's Avatar
Thanks that's what I wanted to know. I don't have to change any springs or anything? The original setup on this diverter valve was for my stock turbo. I'm currently on a FP3582R on SD. I plan to be around 530-600awhp.
Old Apr 27, 2012 | 10:09 AM
deylag's Avatar
Taken from the Synapse Engineering Website Catalog:
By design, it is a pull-type valve only. This means that boost pressure keeps
it closed, meaning no boost leaks upwards of 100+ psi of boost.
Old Apr 27, 2012 | 10:56 AM
GTijoejoe's Avatar
They have two different valves, the newest valve which is much smaller can run in any config and hold 60psi I believe. IMO the best way to mount it is to use the welded on flange and not use a coupler.
There is an adjustable spring inside the valve which can be tightened if needed, there are also other aftermarket springs ppl have used, every setup is slightly different so not many ppl will be able to give you a definitive answer but only their experience.
snopro32
For Sale - Part Outs
Aug 12, 2012 04:04 PM
whitersevo
13
May 6, 2012 03:27 PM
MISHI
Dec 16, 2011 07:24 PM
E46byeRAhi
Aug 2, 2011 04:24 PM
GRAPHITE RALLI
09+ Ralliart Show and Shine
21
Mar 10, 2011 04:18 AM
