BR Double Pumper "My car hates me!"
Old Apr 28, 2012 | 10:56 AM
5LEEPERISAH23I's Avatar
so i installed a BR double install went real smooth. Started right up rans, idles, ect.. BUT the next day started and looked at the pump housing and fuel was everywhere! im like WTF!? so clean it off let it dry. Start it up and its leaking out the center of the top of the housing!? its not leaking out the sides or out of a line. BUT I DONT SEE A CRACK or where it is leaking im so confused.. am i overlooking something anyone else have this problem??
The tip of the flat head is were it is leaking.. that white ring part.. PS i no there are wires everywhere will clean up after problem is fixed
UPDATE Sent it back to BR. I put it back into my car. Problem fixed
Old Apr 28, 2012 | 01:20 PM
pls1968's Avatar
There is a black plastic nut on the top of the housing thats probably loose. The one where the red and black wires come out of. Try tightening it and be careful not to overtighten as it can break.
Old Apr 28, 2012 | 02:15 PM
i cleaned up area let it sit/dry and this is were it is leaking out the white ring part
Old Apr 28, 2012 | 02:41 PM
CurseDSM's Avatar
doh looked in the wrong spot. You may have to take it out and look to see if theres anything loose under there.
Old Apr 28, 2012 | 03:04 PM
Evoryder's Avatar
Have u called the Buschur before u hack out the warranty
Old Apr 28, 2012 | 05:15 PM
GR8WHITE RS's Avatar
i had the same problem, i sent it back to buschur and he took care of it. but all you really need to do is tight the nut underneath.
Old Apr 30, 2012 | 02:02 PM
took it out nothing was loose
the nuts underneth are tight.. both top and bottom.. i used jb weld puddy. didnt work and now it looks like sh*t on the top. but if the problem is underneth i couldnt see why BR could still fix it
Old Apr 30, 2012 | 02:41 PM
DSMpsi's Avatar
He may still help you out, but that was the wrong move on your part. Give him a call and see what he says before it gets messed with anymore. The worst he can now say, is no.
Old Apr 30, 2012 | 04:57 PM
yea i did. he said email him. havnt heard back from him. i thought that JB weld would for sure fix it but i didnt ..
Old May 1, 2012 | 10:14 AM
STIKiller4G63's Avatar
I thought the black nut on which the wires are coming from we're suppose to get tightened on the bottom side of the pumper?
Old May 1, 2012 | 12:51 PM
sorry stupid question on my part -__-
Old May 2, 2012 | 09:44 AM
tsidrift1's Avatar
I have been fighting the same issue. Buschur is working with me on a fix. I have tried tightening everything and I still get a leak from the exact same spot. Its really only when I fill the car up. I dont fill past the click, just let it stop on its own. When mine leaks, it leaks a decent gallon or two out from just sitting over night. Nothing like waking up cause your nostrils burn from the smell of gas in my house.
I am gonna pull mine back out this weekend and install some new bulkheads that I got from buschur. Hopefully this fixes it. Mine is only leaking from one of them. I am also gonna try to install some rubber o rings or washers under the bulkheads and see if that will stop the leak.
Old May 2, 2012 | 10:25 AM
dprez25's Avatar
send it back to buschur. they should warranty it
Old May 2, 2012 | 11:26 AM
i took off the JB weld stuff. Talked to them on the phone. They said send it back so i did so. So im not going to complain. But yea my nuts and bolts were all tight. I had a 1/2 tank of gas of it was leaking out. Only at one of them tho.
Id recommend instead of trying to fix it yourself just sent it off to BR. I was told on the phone they have not been able not to fix one. so ur chances of them fixing it are pretty high
Old May 2, 2012 | 11:40 AM
David Buschur's Avatar
Guys, in the odd chance you get one of these that has a leak, DON'T DRIVE THE CAR. Figure out what the issue is, contact us and either let us fix it or try it yourself.
Most common problem is people forget to install the big fat flat o-ring between the tank and fuel pump assembly.
The nylon flat washer we use sits on top because it's a nice flat area to seal. The fittings have a large AN nut on the bottom and Jarrod tightens the crap out of them. There shouldn't be anyway a leak can even happen there as tight as they are.
We'd be glad to look at it if you send it back.
BTW, I just checked my mail, I have no messages from you.
