Pcv
Old May 1, 2012 | 06:50 AM
seventh_rx's Avatar
Pcv
Hi everyone,
It appears that I possibly have a plugged PCV (I hope!) due to some white-ish smoke coming out under high boost.
I've been searching for a how-to or any kind of thread that shows you how to remove/check the valve. I remember spotting one thread that said to look in the car manual for instructions but I haven't had any luck finding it around the house.
Any help would be greatly appreciated!
Old May 1, 2012 | 06:54 AM
binky's Avatar
Here's a link to the manual(s):
http://www.evoscan.com/vehicle-manuals
White'ish smoke usually indicates coolant being burned off. Have you noticed your coolant levels dropping at all?
-Bink
Old May 1, 2012 | 07:21 AM
seventh_rx's Avatar
I haven't noticed any difference with the coolant level. The overflow is still at full and the radiator level is at the top.
Not much going on with the oil/oil cap from my initial inspection. I will get a better look when I change the oil this weekend.
Thank you for the link btw!
