Sticky throttle at cold engine temps
Old May 20, 2012 | 12:38 PM
cazlow's Avatar
When you install new ones, use a little white lithium grease. My throttle was a little sticky when cold for about a week after I installed them but it went away. Mine were the culprit of a ridiculous boost leak. No issues now though. Easy install.
Old Jun 21, 2012 | 07:30 AM
9!'clipseDOHC's Avatar
FCOTM Winner
Just to add to this I replaced my TB shaft seals and the problem went away 100%. If anyone else is having an issue with sticky throttle on cold starts, deffinetly take the time to do this. It is cheap, easy, and well worth it!
Old Jun 21, 2012 | 07:38 AM
llDemonll's Avatar
I have my new ones sitting in the bag still...not sure when i'll get them in but hopefully I will also be able to report back that the problem was 100% fixed!
Old Feb 4, 2013 | 04:40 PM
Dantheman11's Avatar
I have this exact same issue, thanks for posting up the advice! I will be ordering a new set of seals asap.
Old Feb 5, 2013 | 01:17 PM
clubEVO93's Avatar
This is great to read! I have the cold start and pedal sticking problem! Its very annoying. Gonna try to use the cleaning method first
Rom
Apr 2, 2017 04:53 PM
W0LF
Sep 15, 2016 08:58 PM
Babs
Oct 7, 2015 04:05 AM
Qshiplvr
Feb 9, 2015 11:18 PM
atilla
37
Nov 8, 2010 05:11 PM
