I know this is an old post.. but in case anyone else checks it, or needs the info.
The HVAC, Ignition key ring, and cigarette lighter are size 74 bulbs.
The ACD/Fog Lights/etc. are NEO3 Bulbs.
Quote:
I didn't know the fog switch lights up. Injust ordered a few neo bulbs.Originally Posted by Syringe
I know this is an old post.. but in case anyone else checks it, or needs the info. The HVAC, Ignition key ring, and cigarette lighter are size 74 bulbs. The ACD/Fog Lights/etc. are NEO3 Bulbs.
Quote:
Size 74Originally Posted by itzCiel
do you happen to know the exact number of bulbs for each type to get that set up?
3 for HVAC
1 for ash tray
1 for cigarette ring
1 for key ring
Edit: Note* If you get LEDs make sure you get side projecting ones as well.. (similar to this: http://www.superbrightleds.com/morei...edge-base/228/) or you will have 3 brighter spots as LEDs output is more focused.
NEO3
You only need 1 per switch but I think i put 2 in all of them but 1..
So.. Math = 7
Quote:
Which ones did you order? SuperbrightLEDs?Originally Posted by flippymcbean
I had to take the contact tabs and bend them over and stick them through the hole, I soldered them to the circuit board on the proper contacts so they wouldnt ever wiggle loose.
Quote:
3 for HVAC
1 for ash tray
1 for key ring
NEO3
So.. Math = 7
Size 743 for HVAC
1 for ash tray
1 for key ring
NEO3
So.. Math = 7
I ordered some ebay crap. Just to see if its in working order. I got some 74's from V-leds.com
I only wanted to see what it was like. $10 for the neos, and i read the NEO 5(5mm) will suffice. But I didnt know the Fog light button has a light. Does Hazard have one too? My A/C light is out, but that i need to cut and solder. So bueno for me.
If you want both hot/cold to both be red change the bulb, but if you want cold to be blue and hot as red then use acrylic paint to color the clear plastic piece.
Check post #11 to see my setup.
I painted some using a red Sharpe and used the red condoms to replace the oem blue ones for the others....works great to this day. I still have to do the clock ... :-/
Any tips on that? Never got around to searching for a How To on changing the clock to amber/red.
That I'm not sure what size it is. mine is the factory red still.Originally Posted by flippymcbean
I ordered some ebay crap. Just to see if its in working order. I got some 74's from V-leds.comI only wanted to see what it was like. $10 for the neos, and i read the NEO 5(5mm) will suffice. But I didnt know the Fog light button has a light. Does Hazard have one too? My A/C light is out, but that i need to cut and solder. So bueno for me.
Quote:
3 for HVAC
1 for ash tray
1 for key ring
NEO3
So.. Math = 7
what about the cluster? what size leds does it use? or did you solder them on?Originally Posted by Syringe
Size 743 for HVAC
1 for ash tray
1 for key ring
NEO3
So.. Math = 7
