E85 vs fp green
Old May 24, 2012 | 05:23 PM
High_PSI's Avatar
Originally Posted by auni93085
A friend of mine has a stock turbo with tbe, injectors and e85 tune. He is pushing 345hp and 370lbs @ 30psi. I have a fp green pushing 400hp and 370lbs @24psi with supporting mods.. 1050's and 93 octane. Both have evo 9's. Why is he keeping up with me?
Torque. you have higher PEAK numbers but his torque probably hits like a jackhammer and a much FATTER curve then yours. Remember WHP isn't real, only torque is. He spools faster and holds more torque until higher RPM's. Get E85 and you'll kill him. Also after 100MPH I'll bet you'll pull away up top.
Old May 24, 2012 | 10:14 PM
auni93085's Avatar
That is the plan. Tuned to E85 and cams and gears should put my above 450 torque and above 500hp.
Old May 24, 2012 | 11:50 PM
toyotabike's Avatar
he took you everytime
Old May 25, 2012 | 01:09 PM
mikeywick821's Avatar
Granny shifting not double clutching like you should lol
how fast were you guys starting on your pulls?
Old May 25, 2012 | 04:00 PM
auni93085's Avatar
Hahaha. That was a good laugh after a long day! I believe I started in 4th gear at around 4000 rpms. Speed is irrelevant. I usually forget to look at the speedo most of the time anyways..
Old May 25, 2012 | 04:07 PM
Airman X's Avatar
Yea he pulled on you everytime...e85 WILL do the trick lol
Old May 25, 2012 | 09:21 PM
Svendiesel's Avatar
If you do E85, check your injectors after 500 miles or so. If theyre clean, check them after 1000. Continue to do so til you find, if you find, your injectors are clogging. When you start seeing E85 gunk on your injector tips, drain your E85 and run a few gallons of 93 oct through your motor and that will clean them 100%. I run a few gallons of 93 through my tank roughly every 1000 miles.
Just to be sure it was working and actually cleaning, I pulled my injectors after driving with the 93 for a little while. Injectors were perfectly cleared up.
Old May 25, 2012 | 09:33 PM
lostsoulsevo's Avatar
torque gets you down the 1/4mile faster, F*^k hp!!
Old May 26, 2012 | 12:39 AM
CJ2X's Avatar
Keeping up is not the word... Beating is..
Old May 26, 2012 | 08:49 AM
auni93085's Avatar
Wait. U can just run 93 on a e85 tune whenever u want? What if I run e85 on a 93 tune? regardless I want it. And it smell sooo good too)
Old May 26, 2012 | 11:33 AM
evo8426's Avatar
No, injector scaling is completely different. An e85 tune is much more aggressive and running the same timing is very likely to blow the motor. The tune for each fuel is totally different.
Old May 26, 2012 | 11:48 AM
Zerokei_XF's Avatar
Just run the Tephra mod and get a map switch, I run E85 and 93 all the time. If I can't find E85, run it till fuel light is on, flip switch, fill with 93, and put put on.
Old May 26, 2012 | 12:08 PM
1meandsm's Avatar
u need more seat time... haha.. there is no reason you should be losing to a 6 speed car... e-85 or not.. u have longer gears and more power..
im gonna go with your problem being Driver mod
Old May 26, 2012 | 12:30 PM
tim85851's Avatar
+1
...before switching to e85 try this: re-race him and start in 2nd gear...BRAKE BOOST! See if that changes anything...
Old May 26, 2012 | 01:38 PM
auni93085's Avatar
Got another run in. MUCH BETTER! Started off in second this time and we both honked. This time was totally diFferent. I pulled on him in every gear... Not by much but, still I pulled away. Shifting properly really makes a huge difference he said he was break boosting before. This time no break boost.
