Rusting Normal?
Old May 24, 2012 | 10:25 AM
jordanwince's Avatar
Rusting Normal?
Thanks for the help guys!!!
Old May 24, 2012 | 10:29 AM
gsrboi80's Avatar
Is it the tubing or flange or both. Is the flange mild steel??
Depending on the SS used it can get some surface rust. A lil WD-40 and a scotch-brite pad will take it right off usually
Old May 24, 2012 | 10:32 AM
Yea i think it is just superficial rust per-say. Its just on the flanges.
Old May 24, 2012 | 10:33 AM
sr20det91's Avatar
unless toxic fab is high grade stainless steel its pretty normal. Anytime you have something that constantly heat cycles it's going to discolor and corrode over time.
Old May 24, 2012 | 10:35 AM
Sounds good. Toxic fab is a pretty penny so therefore I was kinda getting a bit worried. Thanks for your help guys.
Old May 24, 2012 | 11:07 AM
ToxicFab's Avatar
Mild steel flanges will rust sir. Absolutely normal.
Pm me if your having issues with the rust.
-Collin
