Click when trying to start
Old May 26, 2012 | 11:00 AM
wazzelby's Avatar
Ok so for a while now I've had this intermittent problem. When I turn the key it clicks once. It sounds like it's down by the starter. If I turn the key like 20-50 times it eventually starts right up. I thought it was the starter going bad, but it's not. Here's what I tried so far.
Replaced the starter
replaced the battery
cleaned the ever living hell out of the battery terminal connectors
checked all the fuses
I have no idea what else it could be???? Anyone ever had this issue?
Old May 26, 2012 | 11:11 AM
techghost's Avatar
FauLty Main relay?
Old May 26, 2012 | 11:15 AM
wazzelby's Avatar
any idea on how to check that?
Old May 26, 2012 | 11:40 AM
techghost's Avatar
I don't know its location but I had similar issue in my honda and it was a faulty main relay, replaced it and bang! Everything was fine!
Old May 26, 2012 | 02:01 PM
wazzelby's Avatar
ok, I found the relay. I'll order one up and see what that does. Thanks.
Old May 27, 2012 | 06:56 AM
BoostINurI's Avatar
Maybe your clutch switch
Old May 27, 2012 | 08:55 AM
wazzelby's Avatar
I have that bypassed. Plus I tried hooking it back up. NO luck.
I'm going to try and test the wiring going to the starter. check for voltage drop. Not sure what else to check. I'll update this with what I find out.
Old May 28, 2012 | 03:10 AM
techghost's Avatar
^ did you tried changing the relay?
Old May 28, 2012 | 03:54 AM
lostsoulsevo's Avatar
check the white wire for the starter solenoid. thats sounds like your problem. either the ground or the white wire or starter solenoid is bad i believe
Old May 29, 2012 | 02:23 AM
lopillo_evo's Avatar
Veteran: Army
this happened to me on my evo. It was the ground!!!! I couldn't believe it!!! It also happened to my buddy we put a bigger wire and a ground kit and the car started normally hope this helps
Old May 29, 2012 | 09:07 AM
Veteran: Army
I'm telling you man change your ground put a thicker gauge one and put a ground kit I bet you that is the problem it happened to me before and I was going crazy and also my friend on his evo same problem the ground
Old May 29, 2012 | 12:02 PM
wazzelby's Avatar
Do you mean the "S" wire? I tried cleaning that and crimping it a bit. No change. I need to do a trace on it to see if it has a voltage drop next.
When you say to change the ground, which one are you talking about? The starter is grounded by the bolts that bolt it to the flywheel housing. I added a ground from the starter housing to the frame and it's still doing the same thing. Are you saying to add more grounds to the battery itself? It seems pretty well grounded already.
Old May 29, 2012 | 02:47 PM
Veteran: Army
I changed the hole thing especially the one going to the battery when I touched mine it was hot as f**** so i replaced with a 0 gauge one, then from the chassis to tranny, tranny to head, head to chassis.
Old May 29, 2012 | 03:32 PM
blowngasket's Avatar
Agreed with the above posts, put a bigger and better ground wire on the car from the battery to the block
Old May 30, 2012 | 03:48 AM
check your ground, but i really thinks its the solenoid. the "s" wire connects to the solenoid....it looks like a spark plug wire. change it
