Driving the RS and the Evo 8 Blindfolded
Old Jan 26, 2004 | 09:02 AM
Blue Evo 8's Avatar
I'm seriously considering buying the RS when it is released.
What performance differences can you tell if you were driving both cars blindfolded?
Would it be noticibly faster?
Would it noticibly outhandle the regular EVO?
P.S. Do not drive any car blindfolded!
Old Jan 26, 2004 | 09:48 AM
Secret Chimp's Avatar
The car is not yet released. So there is no way for anyone to factually answer your questions.
If you read Motor Trend this month, you know as much about how the Evo RS will handle as we do.
SC~
Old Jan 26, 2004 | 10:00 AM
speedomodel's Avatar
Sports Car International (March 2004, No. 161) drove the VIII and the RS back-to-back at Willow Springs Intl. Raceway and had this to say:
"The RS feels a touch more nimble and a little more eager to rotate than the standard car. The RS feels more sensitive to mid-corner throttle or brake inputs. Trail-braking into a turn or abrutply lifting off the throttle before the exit brings the rear around in a nice, predictable manner. Plus oversteer was more easily controlled in the RS than in the standard-issue Evo.
"While having slightly less mass may have contributed to the RS's friendlier feel at the limit, the car's front limited-slip differential played a more discernable role. This device let us get back on the throttle incredibly early, thus taming the oversteer more quickly and allowing for even stronger acceleration out of the corners...
"'But what about acceleration,' you ask, 'does the RS feel any faster in a straight line?' Well, um, err, no. Actually, the Evo with the vanity mirrors and extra grab handles felt a little faster, but this was due to the fact it had nearly 20,000 miles on it; the Evo RS we drove was not fully broken in yet. But still, we feel that we could go marginally faster in the 'green' Evo RS, and in the end, better lap times are the RS's raison d'etre."
Other observations. The Brembos are still fantastic, even without ABS. The front LSD has no discernable drawbacks. "The front end did hunt around slightly more than the regular Evo's, but without any of the STi's wheel-tugging antics."
It's a pretty good article and they follow it up with a close look at the 2003 SCCA ProRally Evo.
If you're willing to lose the HID's, rear wing, ABS, power windows, sound deadening materials, trunk trim, air conditioning, rear window wiper, central locking, keyless entry, then go for it. Personally, I wouldn't want it as a daily driver. However, I hope there's a group buy organized for the RS's helical-type mechanical front LSD and trunk brace that our full-blown Evo's don't have.
Old Jan 26, 2004 | 11:52 AM
Blue Evo 8's Avatar
well, at least I know it handles better, with some strut bars, stabilizer bars and maybe some sway bars, handling could be better. I plan on keeping the stock springs and shocks though
I wont keep the motor stock
cool brakes!
I dont mind losing all the above. I'll just buy a 5100K Philips HID kit and throw it on.... call it a day
Old Jan 26, 2004 | 12:04 PM
tsi90awd's Avatar
The handling differences described in that article could just as easily be due to a difference in the wheel alignments as opposed to LSD, lower weight, etc. Evo handling seem fairly sensitive to wheel alignment, especially front camber.
The factory front camber of the normal Evo seems to be typically 0 to -0.5 degrees. I wonder what the factory alignment is of the RS?
Old Jan 26, 2004 | 12:11 PM
LDB's Avatar
LDB
The RS with the Urban Jungle package sounds like as close to perfect daily driver as can be found. If it just had the rear window wiper and HID's it would be set. Then again, there's only about 50-60 pounds difference to the VIII with no sunroof and the RS so with the UJ package it's probably only 20-30 pounds so probably no point in going RS UJ and just get an VIII with no sunroof.
Old Jan 26, 2004 | 12:22 PM
s4awd's Avatar
I just want that front diff
Old Jan 26, 2004 | 03:00 PM
I <3 Boost's Avatar
And please dont drive either car blindfolded.
Old Jan 26, 2004 | 06:58 PM
4ringturncoat's Avatar
I am on a allocation list for a R/S...I like the fact the radio is gone so I can put my own in. Don't drive much at night so no need for HID's. I have an Audi S4 now and if I like the R/S I will get rid of the S4. I do like to go to the track and any weight of the car is good. Do the Buschur kit (-56lbs), lighter track wheels (-20 rotating), remove spare (-40) and you have a pretty light track/street car I can still get two kids seats in.
Old Jan 26, 2004 | 07:50 PM
Blue Evo 8's Avatar
Yep, thats my philosophy. Did they say how much they'd charge you for the RS?
Old Jan 26, 2004 | 09:59 PM
Here's another perspective from Sport Compact Car (March 2004, Vol. 16, No. 3), who also tested the Evo VIII and RS back-to-back at Willow Springs...
"The RS is more receptive to mudslide driving tactics as it passes its adhesion limits and rotates much more confidently than the standard VIII. It was far more receptive to direction changes through left-footbraking and more predictable in the execution of maneuvers."
Also, SCC had some bad news for us full-blown VIII owners eager to get the RS's front LSD. Apparently, the addition of the front LSD dictated the loss of ABS. "After all, making ABS work along with three limited-slip differentials is a neat engineering trick that, so far, can only be accomplished with an active center diff." So, I guess we'll need the ACD as well if we want to keep ABS? Then again, this might be an excuse to work on my threshold braking.
Old Jan 26, 2004 | 10:19 PM
yoyoyoyoming's Avatar
so which one is better for race ?????????????!!!!!!!
Old Jan 26, 2004 | 10:34 PM
IgotaWhiteOne's Avatar
i wouldnt buy one if my life depended on it they dont look as good for one and NO AC what were they thinking i dont care what kind of race car i have its going to have ac and anything you do to it will void your warranty mine is voided and thag mungsten moss act doesnt do sh*t they said look in the manual that just what i think...
Old Jan 27, 2004 | 07:40 AM
propellerhead's Avatar
If I were you, the very fact that you're on an allocation list would make me nervous about getting a "turd pushing" from the dealer. With only 500 units there are already urban legends of rediculous markups on the RS. Why pay $32k-$35K for the RS when you can buy a regular trim Evo for $27k-$29K? You'll have the cost of your planned mods covered in the price differential. It's always easier to take **** out than add it in later. I'm not so certain the deletion of the front LSD is worth the loss of the sport ABS and the slightly improved handling.
Regardless of which trim level you choose, I think you'll be happy. I made the same switch from an APR Stg1 '00 S4 to the Evo. I haven't looked back since. Once my BR Stg3 is set up I'll have that "freight train" pull that my chipped S4 had, plus I'll have handling and braking that alot of S4 owners pine for.
"Even trip to the grocery store feels like a transit stage on a pro rally."
Old Jan 27, 2004 | 07:46 AM
YellowFever's Avatar
The Evo RS has an "urban jungle" package, which throws back on the power mirrors, keyless entry, power windows, and some other things I can't remember. I got this info from the Sport Compact CAR , not Sport Compact International, SpeedOModel
