2 questions..... Your opinion matters
Old Jun 1, 2012 | 06:55 PM
fastyouth1313's Avatar
My evo 8 has 91,xxx miles and...
Compression is 150/155/158/158 is that good?!?!
And my turbo inlet and coupler from my intake have some oil In it and I'm running a catch can and there is no oil in the catch can lines or the intake tube itself does that equal blown turbo???
Leave your response please
Old Jun 1, 2012 | 07:08 PM
casper980's Avatar
Your compression is fine, If one cylinder was like 135 you would have a problem. As far as the latter, that sounds odd to me...I am sure someone can help with that.
Old Jun 1, 2012 | 07:31 PM
PatricksEvilEvo's Avatar
That's good compression. Check oil seal, if your turbo was bad you'd be smoking.
Old Jun 1, 2012 | 07:34 PM
Oil seal where are you referring to? The blades are oily?
Please help and thank you
Old Jun 1, 2012 | 07:35 PM
There is a very small amout of in and out play
Old Jun 1, 2012 | 07:47 PM
barneyb's Avatar
I've had sparkling clean oil in the intake when the oil in the engine was in need of changing. This tells me that oil leaves the engine vent as vapor and then condenses in the intake.
Old Jun 1, 2012 | 07:54 PM
But my I take tube is oily, just the turbo blades and inlet and a bit of the coupler.
Old Jun 1, 2012 | 08:16 PM
Your intercooler, piping and throttle body are probably coated too. Mine were after 40k miles stock. I was shocked at how much oil was in my intake tube, maf and stock ic. But that was recirculated blow by. If you have fresh oil in it I'd assume a turbo oil seal. This is blow by
not so fresh
Old Jun 1, 2012 | 08:25 PM
Oil is about 900 miles old, and the oil in turbo inlet was kinda blackish
Old Jun 1, 2012 | 11:26 PM
More opinions please! They all help!
Old Jun 2, 2012 | 08:42 AM
90zcrex's Avatar
The stock pcv system tends to cause this buildup as the pcv valve leaks a tiny bit and when in boost pushes some of the crankcase gases into the air filter tube and into the turbo, coating everything with oilover time. If you've ran the stock pcv system for an extended amount of time this could be what your seeing. I would clean it all out as best you can and run it and keep an eye on it.
Old Jun 2, 2012 | 09:14 AM
I am doing that now, but I run catch can and everything is on intake us clean, you talking about the valve on the back of the valve cover?
Thanx!!!!
Old Jun 2, 2012 | 09:30 AM
02BLUR's Avatar
Well, My 1990 Eagle Talon Awd has compression of 145, 125, 110, 120....and it still runs great! And that was awhile ago, its probably lower now! But whatever...
So your motor is doing great!
Old Jun 2, 2012 | 09:35 AM
Are talking about the valve in the back of the cable cover? I'm cleaning it out now to monitor it thanx for your input!!
Old Jun 2, 2012 | 09:36 AM
Makes me feel good! 4G63 FTW!
