Where does this plug into? Need help!
Old Jun 2, 2012 | 10:20 AM
Graphic's Avatar
The plug in this picture comes off of the wiring harness for the alternator.. I kinda had to loosen things up to get it out this side to get a real picture.
What plug is this and where does it connect to?
FYI: this is not the coolant temp sensor connector.
Old Jun 2, 2012 | 10:23 AM
foxbear2277's Avatar
Back of the block their is a sensor below cylinder 3 and 4... If you feel around you will feel a prong on a sensor. Plug it on that
Old Jun 2, 2012 | 10:26 AM
Graphic's Avatar
What sensor is that.. I'm not sure if there is one installed on my block since I have been piecing parts together.
Old Jun 2, 2012 | 10:30 AM
Graphic's Avatar
Ignore the red arrow
I take it's the sensor close to the bell housing..
What is this sensor for? I don't have all data infront of me atm..
Old Jun 2, 2012 | 10:35 AM
Not 100% sure what sensor it is but its the one to the left of the intake mani bracket..the gold sensor
Old Jun 2, 2012 | 10:42 AM
evilempire76's Avatar
I believe the one you circled in the picture is the knock sensor.
Old Jun 2, 2012 | 06:30 PM
EvilEVO800hp's Avatar
ya u circled the wrong sensor......it goes to the one left and a tad bit down the one u circled! i think its an oil temp sensor?
Old Jun 2, 2012 | 07:13 PM
MonsterEvol23's Avatar
Its an oil pressure sensor
Old Jun 2, 2012 | 07:19 PM
barneyb's Avatar
Actually, just a switch. When oil pressure is low it illuminates the idiot light.
Old Jun 2, 2012 | 07:38 PM
Good to know, I was going to look at the wiring diagram but now I dont have to ... Thanks for the info
Old Jun 2, 2012 | 08:02 PM
Graphic's Avatar
Yes I wrote ignore the red arrow.
I know I said ignore the red arrow. Thanks though
Cool thanks man I know it's a sending unit, but I didn't quite know what it was.
Good to know!
Old Jun 5, 2012 | 09:49 PM
kpr's Avatar
kpr
If you have an oil pressure gauge then you dont need it, unless you just want the extra safety of a light turning on. If its not connected no cel or oil lights come on.
