Gauges 60mm to 52mm
Old Jun 11, 2012 | 12:56 PM
projektevo9's Avatar
Gauges 60mm to 52mm
Anyone use these or know how well they work
http://www.rallysportdirect.com/ATI-...rce=GoogleBase
Have a set of 3 Defi gauges looking to switch boost out because it only reads to 30lbs wanted to install the aem digital that reads to 50psi. Have the pod located above the hvac controls if anyone has any better suggestions please let me know. Thank you
Old Jun 11, 2012 | 01:00 PM
Just realized that was backwards I need a 52mm to 60mm adapter anyone know of any?
Old Jun 11, 2012 | 02:08 PM
llDemonll's Avatar
Drill out the 52mm so they fit a 60mm gauge? there's no other way to make a 60mm gauge fit in a 52mm mounting solution
if you have a center mount solution the only real choice is to sell it and get a 60mm one. will look like **** if you try and make the 52mm into a 60mm
Old Jun 11, 2012 | 04:21 PM
I'm trying to fit a 52mm gauge in a 60mm spot not vice versa looking for a piece that tapers from 60mm to 52mm anyone?
Old Jun 11, 2012 | 05:53 PM
STLEVOIX's Avatar
http://www.perrinperformance.com/uni...-adaptors-pair
They will let you buy 3 if you order over phone. This is what i used.
Old Jun 11, 2012 | 11:26 PM
llDemonll's Avatar
I'd go with the AIT ones personally. Perrin ones just look like they cut up some silicone
Awesome thank you
hooliganSKATE
Mar 12, 2016 09:20 PM
bdrever
Apr 23, 2015 10:54 AM
2010wwevox
Mar 7, 2014 12:16 PM
kickin wing
Oct 18, 2010 11:01 PM
Evol X
May 10, 2010 08:32 PM
