Help: Front Lower Control Arms
Hello evo experts!!!
I need to replace front lower control arms.
Is there good aftermarket ones ?
Or.... OEM arms are good enough to have fun on the street ?
Also, Im thinking to replace all bushings.
Have you guys used the Energy Suspension Bushing Kit ?
Thank you!
Thank you!
stay with your stock ones and replace the bushings. bring to a machine shop to get them pressed. whiteline sells some good stuff. i also suggest getting the whiteline center roll correction if you're sitting on coilovers
Why do you think you need to get new Lower Control Arms? Dont know anyone that sells after market best bet maybe find used ones. and bushing you can use on the street. will give you less slack. Not a bad upgrade if you have the parts aport why not do it
Thanks for all inputs guys!
I think I will get OEM front lower control arms.
Do you guys prefer whileline bushing kit for front lower control arms or energy suspension bushing kit for all bushings?
I would not run the energy kit for the front LCA. I run the following combination:
- Inner rear - Perrin PSRS
- Inner front - Stock (IMO a poly bushing to too restrictive to be used with the PSRS)
- outer - Whiteline FRCK
l8r)
l8r)
I would use OEM control arms.....but if you absolutley need to have aftermarket control arms.....Nagisa Auto Japan makes some of the nicest I've seen.
Here is a link:
http://www.more-japan.com/nagisa-aut...lower-arm.html
Here is a link:
Here is a link:
Here is a link:
There is no reason to replace your factory aluminum arms.... they good ish
Here is a link:
Here is a link:
KFC-AWD
Jul 27, 2016 05:35 PM
FS[Northeast]: Complete New Whiteline Suspension Setup
OverBoostedEvo
Apr 9, 2015 01:14 PM
Blue Evo 8
Jul 20, 2013 11:46 AM
Racman709394
Mar 17, 2009 02:35 AM
