My VIII blew up a rear end in 10 mins!
The original rear diff is shot. I pulled out the drain plug and it was filled with shavings and a couple chunks of ring and pinion debris.
I stopped by the shop to take a look at the damage. He still had the drain pan under the t-case. There was a palm sized area of dark brown gear oil that looked pretty thick, and a few small chunks in it as well. I found several used transfer cases on ebay, probably going with one of them. I think I should I grab an ACD pump as well just to be safe.
Firefighting and EMS are my adrenaline fix, lol. Some people sky dive... I run into burning buildings, pull people out of car wrecks, and try to keep them alive. Fun times
Got a good deal on a used t-case, should have it next week. Then once that's in I'll be putting the new wheels and tires on, doing some wiring for the blue lights, cluster, and a-pillar gauges, and detailing the crap out of it for a car show next month.
Well since the rear end I got in last week already had the mounts on it, I decided to put in some Torque Solution urethane bushings in the spare mounts I now have. I sanded them down, cleaned them up, and went to cut out the old mounts with a saws-all.
Didn't work to well, the saws-all had a hard time cutting through the rubber. So I switched to a hack saw, but it didn't fair very well either. So I said F it, I'm bringing out the big guns!
Torched out the old ones, just need to make a couple cuts on the outer rings to knock them out. I also put on a few good coats of black Rustolium to keep them nice.
I don't think you have to drive it around and then check the TC case again. The case only takes less than a quart of Diaqueen. Just make sure to pump it in slow then button it up.
I change mine every 10k, probably overkill but there is a lot of stress in there.
