My VIII blew up a rear end in 10 mins!
Old Jun 29, 2012 | 08:39 AM
  #31
Arxylis's Avatar
Originally Posted by deadstockkpomp
nice, that sounds good. not trying to hijack the thread but what type of driving and or problems causes the drivetrain parts to create metal shavings like the ones you described?
Well the shavings in my rear diff were from it imploding and grinding for a couple tenths of a mile until I could pull into a parking lot.
Do you currently have metal shavings in any of your fluids? If so, where and how much?
Old Jun 29, 2012 | 08:42 AM
  #32
deadstockkpomp's Avatar
no i ask because im changing my fluids soon and i want to take a look to make sure everything is going smooth, i dont hear any noises or anything from the rear unless i shift wrong bc my bushings lol. i just hope nothing is wrong bc i just bought the car in march and was wondering if some stalls could maybe chew up the gears or something. this was my first stick car and its 6puck but ive gotten used to it by now
Old Jun 29, 2012 | 08:57 AM
  #33
Arxylis's Avatar
From what you described you should be fine. A stall here and there shouldn't hurt anything. It's a little rough on the drivetrain, but no where near as bad as launching it. The drain plugs are magnetic, so you should be able to easily see any shavings that might be present.
Old Jun 29, 2012 | 09:23 AM
  #34
the fluids have 10k and i dont launch and i know the previous owner did not, the one before the previous did auto-x but i dont believe he was on this fluid i have now.
Old Jun 29, 2012 | 10:43 AM
  #35
Anarchy99's Avatar
It sounds like it was a transfer case all along and never the rear differential. You very well may have two good rear differentials now and one bad transfer case. I have yet to see one rear differential break on an evo
Old Jun 29, 2012 | 11:24 AM
  #36
Arxylis's Avatar
From the chunk of ring that fell out and the glob of shavings that were on the drain plug when I removed it, I'm fairly certian the rear end took a crap. I'll post some pictures of the carnage when I get home this evening and pull off the end cap.
Old Jun 29, 2012 | 02:19 PM
  #37
Anarchy99's Avatar
The transfer case probably locked up power to the rear wheels and prevented the driveshaft from spinning. if this happened while the car was moving then either your rear tires would lock up or you would blow your rear differential
Old Jun 29, 2012 | 07:25 PM
  #38
Arxylis's Avatar
Here's the pictures of the rear end...
The outside:
And the carnage:
Old Jun 29, 2012 | 07:32 PM
  #39
Arxylis's Avatar
Judging by how all the teeth on the ring gear are stripped fairly uniformly I would say you are right. The driveshaft stopped turning but the rear wheels were still in motion grinding down the ring and breaking pieces off from being forced across the pinion that wasn't moving.
David Buschur
114
Feb 4, 2013 09:02 AM
webguy330i
Nov 16, 2012 08:59 PM
David Buschur
86
Oct 21, 2010 06:36 AM
David Buschur
Jul 18, 2009 02:38 PM
Webman
Jun 4, 2009 07:39 PM
