I/C piping question
Old Jun 27, 2012 | 09:30 AM
DormantBeast's Avatar
I/C piping question
Hey guys if i get a 2.5 in i/c oulets and later want to run 3" I/C piping can i just slap a 2.5-3 " coupler to the i/c would that work like having 3" oulets on the i/C or is it necessary to get a 3" outlet IC?
Old Jun 27, 2012 | 01:26 PM
foxbear2277's Avatar
If you plan on going to 3" piping, I would personally get a ic with 3" outlets and then use a reduce from 3" to 2.5" for now and then when you want to go to 3" ic piping just get 3" couplers...
It is not necessary to get a 3" ic as it will work just fine with 3" ic pipes that reduce to 2.5" at the ic...
Either way works, but if I was going for big power to actually need and gain from 3" piping I would want the ic to not be restictive at the inlets and outlets either
Old Jun 27, 2012 | 01:52 PM
Thnx for the opinion
well i want to fully build this car with either a HTA86 or im looking at the 6466 with magnus V5, 2150cc injectors both E85 and pump, 75 Mil TB, port head, 1.5 in manifold runners, everthying also needed the that type of build lol I dont know on whether or not i want to up the displacement yet.
Old Jun 27, 2012 | 01:58 PM
Well personally I picked up a hta 3586, running ets 2.5" piping, ams ic with 2.5" inlet and oulets, magnus v5, boomba 3" tb with smooth reducing spacer from 2.5" to 3", ported head with a fully build 2.3rpm... I will not be on e85 but rather pump gas 94 octane... I dont think my 2.5" pipes will restict me all that much to be honest which is why I went 2.5", I want best power-spool possible Goodluck on your build
Old Jun 27, 2012 | 02:13 PM
interesting setup, I will stick to 2.5 for now and im sure like u said either way should work im not going to try to break any records just make my car fun to drive
Im thinking about going twin scroll for either turbo as well instead of the single.
Is the difference b/w the different displacements make them that worth getting? Kinda big bucks... I was thinking about going with just a built 2.0 just gonna be my DD/ Weekend Warrior
Old Jun 28, 2012 | 12:48 AM
jrblackSE's Avatar
I currently have a HTA86 and I am running 2.5 piping. My intentions are to crack 700. But I don't necessarily want to reduce spool time. Therefore, I plan on sticking with the 2.5 but MAP recommended I bump up to 3" for the UICP over 700. So based on your intentions, I believe you would be uber happy with the 2.5 piping. Best of luck on your setup
Old Jun 28, 2012 | 10:58 PM
awesome guys thnx for the info ill stick with my 2.5 setup then for awhile . what turbine housing on the HTA u guys using @ both foxbear2277 and jrblackSE... also single scroll or twin?
Thnx I have a long ways to go but im gonna try to be done by next year hopefully
Old Jun 29, 2012 | 01:35 PM
I run a 1.06 ar twinscroll
hutch959
Oct 10, 2016 05:48 PM
vr4_rider
Jun 1, 2011 02:54 PM
jameswwt
Sep 7, 2010 10:28 AM
Evo_Jay
Dec 22, 2005 06:44 AM
accident
Sep 20, 2005 02:31 PM
