DeatschWerks Fuel Pumps
Old Jun 28, 2012 | 06:27 AM
VIIBHR's Avatar
Hey there, as the title says its, im about to purchase a new pump for my evo,
i own a VII.
im taking the DW300 out of mind because i dont need that much of flow in my car.
I know the DW65C is 265lph and the DW200 is 255lph, but which one is a plug in and play for the VIII/IX ?
Old Jun 28, 2012 | 06:43 AM
HaVoC187's Avatar
Buy a Walbro 255 instead, it's probably what most people on here run.
The install kit will have everything you need for a plug and play installation.
Old Jun 28, 2012 | 08:57 AM
VIIBHR's Avatar
Yeah i know, that majority of evo owners run Walbro's, But a local evo tuner recommends the DW over the Walbro, and also i've seen alot switching from Walbro to DW nowadays.
So, all i need is to see which of them would fit my Evo.
Old Jun 28, 2012 | 10:23 AM
HaVoC187's Avatar
DW200 9-201-0847
DW65C seems to have only a install kit for Evo X but don't know if that will work (9-651-1009)
Old Jun 28, 2012 | 12:31 PM
Meathooker's Avatar
DW300 - super quiet, direct drop in, and your car has fpr for a reason
Old Jun 28, 2012 | 12:34 PM
Kracka's Avatar
Depends on your mods and power goals, if 255lph is enough to support them then get the DW200 or Walbro 255HP. If you think you're going to need more, get the DW300. The DW65c is for the Evo X.
Old Jun 28, 2012 | 12:41 PM
meckert's Avatar
The walbro from what I understand is a noisy bugger and it apparently gets louder when its hot-- Thats why i went DW-- flow is great on both and will do the trick. I wanted a "stock" quiet solution.
Old Jun 28, 2012 | 12:52 PM
Kracka's Avatar
This is my biggest complaint; it screams when it's hot.
Old Jun 28, 2012 | 07:38 PM
VIIBHR's Avatar
Thats why im not going with the walbro, i hate the noise ! at the mean time not aiming for more HP, so i will just upgrade my pump because my stock pump failed on me!
So i guess the DW200 is my next pump. thanks Guys.
Old Jul 2, 2012 | 04:06 PM
lanevo005's Avatar
the DW65 is a really nice fuel pump. Ive had it for a little while now and haven't had a problem. knock on wood. Its plug and play and not as loud as the walbro.
e_kobz
May 21, 2017 02:48 PM
DSMolition
Jul 28, 2015 11:25 AM
clip14
Jul 2, 2015 05:49 PM
alexc
Jan 7, 2015 06:03 PM
305EVOx
27
Jan 8, 2013 07:55 AM
