Oiled-Dirt-to-Tarmac-Understeer! Jeez!
Old Feb 2, 2004 | 02:01 AM
rbm3's Avatar
I've never experienced such poor handling!
Sounds like poor driving to me, not handling.
Old Feb 2, 2004 | 05:57 AM
DGS's Avatar
DGS
Oh, like you guys have never been caught out by an unexpected surface change.
You might call that inexperience, but hinting at antisocial behavior seems a bit extreme for an EVO forum. (He did mention waiting for traffic to clear.) Maybe on a Volvo forum.
Back in the '70s (in the RWD days), I was running a nominally tarmac stage through the 'Jersey pine barrens. Most of the "soil" in the barrens is sand. Sure 'nuff, a previous car cut the corner, and tossed sand all over the tarmac.
That really was understeer. The left front shock punched through the hood of my Fiat 124 as the front end dropped into a ditch.
Club rally back in the '70s didn't have tv coverage, helicopter trackers, onboard telemetry, cell phones -- or much in the way of spectators. The next car along had to stop and help us get the car out of the ditch. (The back end was blocking the stage.) That was the worst part: The stage was so narrow that not only did helping us out of the ditch cost him time, it seemed like forever before I had a place I could pull over and let him pass. (I wasn't exactly setting stage records with only three corners of suspension.) (FIAT: Finally, I Am Through!)
But then, the car behind him never caught us up, so maybe it wasn't all that slow. Or maybe he got caught out by the same corner.
Now those were the days.
Old Feb 2, 2004 | 07:29 AM
LDB's Avatar
LDB
If you reread you'll see there was nothing unexpected about it. It was just another incident of his driving "style".
Originally posted by chopdaddy So then I rolled to the end of the dirt road and stopped at the stop sign. I prepared for a right hand turn and waited for traffic to clear. The road I'm about to enter is dry asphalt. Why not? Let's give it another hard launch.
Old Feb 2, 2004 | 07:41 AM
DRWN KIX's Avatar
If you never leave your lane or get close to someone then the more radical the better. I've got passing lane stories just below Big Bear in the snow. Front end let go, then the back end let go. Then the limited slip hooked up. Car was about 10 degrees off actual angle travelled. Eased the throttle car hooked back up. I was passing a long string of cars with oncoming traffic. Stayed in my lane and continued on carefully pulling away from the string. Can you say understeer, oversteer, counter steer and back into the cleaner lane. Wouldn't have wanted to be on the cell phone during this. Maybe he was just giving a cautionary tale. When the surface changes be ready for the unexpected and be glad you are in a car that handles like ours. If you always want to be "on rails" take the train.
Old Feb 2, 2004 | 08:17 AM
Earl Needham's Avatar
Veteran: Air ForceVeteran: Marine Corp
Isn't it interesting how someone will share a "learning experience" and get chewed out for it?
We should instead be using these as "lessons learned" and gain some knowledge from it so others don't repeat this experience.
Anybody wanna hear how a 1965 Ford Galaxie can be coaxed into jumping a bridge and break the rear shocks, exhaust, and blow a tire? Uh, oops, not going to share THAT one!
Old Feb 2, 2004 | 06:46 PM
DGS's Avatar
DGS
The difference between "expected" and "unexpected" is experience.
Old Feb 2, 2004 | 09:00 PM
LDB's Avatar
LDB
There was nothing unexpected about the surface change, he said so in the original post. I'm sure the outcome was unexpected although if one is going to push a car that much it shouldn't be, even with lack of experience. The lack thereof should be the first clue someone has actually, and they should know that because they lack experience there are going to be alligators that bite them in the butt just like this.
Old Feb 3, 2004 | 01:20 PM
DRWN KIX's Avatar
The difference between "expected" and "unexpected" is experience. [/B][/QUOTE]
Experience is something you only get 1 minute after you needed it.
Old Feb 3, 2004 | 01:50 PM
OnlineAlias's Avatar
Sheite, lurid oversteering 4 wheel drifts on slick pavement are a blast...I prolly did that twice on the way to work. Hell, that's why I bought an Evo, KICK *** handling.
lessonz
May 30, 2011 11:37 AM
scheides
Oct 14, 2010 12:08 PM
Arithmetic
Jan 29, 2007 12:49 PM
jedinite
Dec 5, 2003 09:19 PM
