iscv issues
Old Jul 10, 2012 | 10:42 PM
silent_white's Avatar
iscv issues
So, I had a problem where the car would die/ not start when i let off the gas. If I ever so slightly held the throttle, it would start normally and not die.
So I ordered part MD628318 ICSV
Amazon Amazon
as described in the forums here under this thread
https://www.evolutionm.net/forums/ev...out-gas-4.html
Just installed it. The car no longer dies, however my idle is around 1800at idle instead of about 950, where it normally sits. Question being, since the one from the factory didnt have the spring on the plunger and had tabs on the sides that wear out, should this OEM replacement work? Do I just need to adjust the ISCV stepper settings in ecuflash? It would appear that the plunger on the new one either doesnt go out far enough, or the ECU settings are different for the new design and I just need to change them. Does anyone have any experience with this? issues/ resolution?
Old Jul 11, 2012 | 12:44 AM
svt_lightning01's Avatar
I think the 03/04 are different from 05+ if that matters. Not sure in the one from amazon though good luck bro
Old Jul 11, 2012 | 04:57 AM
dastallion951's Avatar
You can try adjusting the idle stepper tables. Or if u go into iirc its sas mode where you can adjust the base idle screw then you can adjust the idle to the desired rpms, then tune the idle stepper tables after.
mrfred
Aug 1, 2022 06:05 AM
Raceghost
Aug 10, 2018 10:39 PM
rartist
Feb 24, 2017 03:46 PM
hans512
Dec 29, 2016 01:15 PM
acid7711
May 25, 2016 09:25 AM
