Evo VIII US-spec, 30 psi?
Old Jul 13, 2012 | 11:56 PM
IamFredrik's Avatar
Hi guys! Im from Sweden and i just bought my first Evo.. its a Evo 8 US Spec, 48k miles and great shape!
Im going to turn up the boost to 30 PSI and then drop to 28.. my current setup:
HKS 272 cams
Garret GT30R
AEM-EMS
1000cc injectors
Walbro 255l/h
Tial 38mm
ETS 3.5" Intercooler-kit
3" from turbo
98 oct fuel (you call it race-fuel)
Ive got some few questions... Swedish Evoforum is kinda so im asking you guys for some advice!
Its a 2003 Evo 8 US-spec... is it true i got forged crank and rods?
Do you think its a good idea to go 30 psi then down to 28 psi?
/Fredrik
Old Jul 14, 2012 | 07:22 AM
khmerpimpin's Avatar
No they are not forged unless aftermarket parts were installed.
Old Jul 14, 2012 | 07:54 AM
Todd06MR's Avatar
Congrats on the new car. From your list of mods, it sounds like it will be a fun car.
But I would caution you to turn the boost up that high. The stock internals cannot take that kind of abuse (for very long). I would stick to the 22-24 psi range to be safer. Unless you can find out if it has aftermarket pistons and rods, I wouldn't push it too hard.
Old Jul 14, 2012 | 10:02 AM
IamFredrik's Avatar
Thx for your answer... hm.. you says its not forged internals... have you read this?
https://www.evolutionm.net/forums/ev...-rods-evo.html
https://www.evolutionm.net/features/...agenumber=4&s=
"The U.S.-specification Lancer Evolution�s 4G63 utilizes a revised and reinforced cast iron block filled with a reciprocating assembly consisting of a durable forged steel crankshaft, and 150 mm forged steel connecting rods; cylinders are filled with low compression (8.8 to 1) pistons cast in durable, lightweight AC8A (T6) aluminum designed to withstand forced induction cylinder pressures for an extended period."
What about that?
Old Jul 14, 2012 | 10:06 AM
1meandsm's Avatar
i DD mine at 30lbs
Old Jul 14, 2012 | 10:11 AM
IamFredrik's Avatar
Originally Posted by 1meandsm
i DD mine at 30lbs
What is DD? Sry never heard that before
Old Jul 14, 2012 | 10:13 AM
evo8dreamcar's Avatar
Daily Drive
Old Jul 14, 2012 | 10:15 AM
IamFredrik's Avatar
Originally Posted by evo8dreamcar
Daily Drive
aaaah! Thx dude, haha
Old Jul 14, 2012 | 03:36 PM
VIIIdriver's Avatar
Everything is in the tune,if the car is properly tuned you can do 30 psi as a daily driver no problem,i was pushing 32 psi on a stock evo 9 turbo at right over 400hp with no issues,keep torque under 450 ft-lb and you should be fine.
Old Jul 14, 2012 | 04:30 PM
IamFredrik's Avatar
Great answer! Thank you so Much...
Now, about the forged internals.. is it true? Mark says its true when its the US-spec... what do you guys say?! Im pretty about this!
Old Jul 14, 2012 | 04:47 PM
Raptord's Avatar
Define "forged". For some people it's just a way of describing a "built" engine.
Old Jul 14, 2012 | 04:49 PM
IamFredrik's Avatar
If its not Forged, its cast!
The material.. like that rod is a cast rod.. and that rod is a forged rod!
Does it make sense what im telling you? Ill try my best, even if my English aint the best
Old Jul 14, 2012 | 05:06 PM
EVO ARCANGEL's Avatar
What about that?
I never really looked into it, but now I'm actually curious.....there are how many guys on here who have taken a 4G63 apart.....someone has to know for sure.....
Old Jul 15, 2012 | 03:42 AM
IamFredrik's Avatar
I totally agree with you dude!
Old Jul 15, 2012 | 01:35 PM
EvoJoeIX's Avatar
Yes evos have forged crank and rods, doesnt mean they can withstand huge amounts of torque though
