OverHeating
Old Jul 15, 2012 | 04:28 PM
Ministroker214's Avatar
OverHeating
So I went to fuel up my car, rolled in perfecting
Fine, filled up, went to take off, an it started making
This really weird noise under neath my car as if my emergency break was on ( a noise the brakes would make, but wasn't coming from the brakes) as I went through my gears it started to continue
I look down at my gauge, it's through the roof, however, I have the 06 MR, so I have the Other gauges, and that temp was normal, reguardless I pulled over and let it sit.
The anti- freeze is full, the gauge isn't broken cause it is decreasing now...and the "brake noise" isn't te brakes, cause it only made the noise as the car was on and driving in a gear. ( I shut off my car and let it coast, and the noise wasn't going on)
Anyone have this sort of problem? It has been sitting for about 2 hours, and the temp on the dash is down to "regular driving" temp.....could it have been hot before, because it is a 90 degree day? Any help would be awesome
Old Jul 15, 2012 | 04:29 PM
quickline23's Avatar
maybe your water pump broke?
Old Jul 15, 2012 | 04:35 PM
Could it go without any leaks of any kind?.. I just started it and the oil temp (gauge cluster) is cold, but the one on my dash is still about halfway, and it was rising for having it run for 30 seconds
Old Jul 15, 2012 | 04:45 PM
i wouldnt think so but if u have a bunch of noises and your overheating maybe it broke and isnt flowing any water through best bet is to take it apart and look at it
Old Jul 15, 2012 | 04:46 PM
or maybe your thermostat?
Old Jul 15, 2012 | 04:47 PM
also i wouldnt keep driving it or starting it till your get it figured out dont wanna warp your head
Old Jul 15, 2012 | 04:57 PM
wazmunstr's Avatar
I have no idea what this "brake noise" is. grinding? squeaking? You don't have any leaks? Take off the serpentine belt and see if there is any play on the water pump pulley.
Old Jul 15, 2012 | 04:59 PM
grillpt's Avatar
Sounds to me like the belt is slipping on the water pump, causing it to not spin and heat up, that or it's ceased. Either way don't drive the car, you'll cook the motor.
How many miles on it?
Old Jul 15, 2012 | 05:42 PM
AndyCT9W's Avatar
It does sound like the water pump has seized and the belt is slipping. How many miles on your car? Has the water pump been changed at all?
Old Jul 15, 2012 | 05:45 PM
It only has 58 thousand on it, and the grinding is like front under neath the car, like something was attached to the drive shaft was hitting the the bottom of the car
Old Jul 15, 2012 | 06:06 PM
grillpt's Avatar
Timing belt and waterpump are 60k service items, just an fyi. Bottom line, you need to get the car looked at.
Old Jul 15, 2012 | 06:25 PM
Previous owner had everythin done for the 60k when I bought it, I have all the receipts, just have to see exactly what he did, but i know he did most of everything..I'll have to wait for tomorrow
Old Jul 15, 2012 | 07:26 PM
1sxyrxy's Avatar
Doesn't mean it couldn't fail. Let it cool down and post a vid Or remove belt and try spinning water pump by hand.
Old Jul 15, 2012 | 09:14 PM
AreSTG's Avatar
though having all new stuff would make you want to believe it couldn't be the problem, if anything wasn't right during the install, having the 60k recently done could be the culprit.
i think a lot of signs point to the waterpump right now, or indirectly, the belt.
Old Jul 16, 2012 | 04:57 AM
Well I took a picture but can't seem to post it on myobile phone, but I started my vehicle this morning and the temp gauge is about quarter the way up ( what it is when I normally am driving it) and its been sitting all night, so clearly the gauge is ****ed up as well?
