Ic sprayer delete question
Old Jul 19, 2012 | 12:18 PM
barneyb's Avatar
Originally Posted by Evoardo IX
Did you tune the IC sprayer setting with ecuflash? If you haven't then whatever it is you are feeling is just in your head, "auto" mode comes pretty much dissabled from the factory, have a read at this:
http://www.mrtrally.com.au/performan...IX-ICSpray.pdf
Yes, I am familiar with the above and nope, not tuned. Good idea though. Took a 400 mile road trip (very hot) and it nearly emptied the bottle. So, it does occasionally run. I need a light that tells me when it is on.
On the other hand, about a week ago I filled the bottle and since have only made short trips about town. So, today I topped off the bottle and it didn't take much until it was peeing on the concrete. Could that little amount have made the difference I thought I was feeling?
Last edited by barneyb; Jul 19, 2012 at 01:00 PM. Reason: decided to write some more
Old Jul 19, 2012 | 01:27 PM
True Blue's Avatar
Can you retrofit the sprayer to a USDM IX?
Old Jul 19, 2012 | 03:38 PM
Evoardo IX's Avatar
Yes, a heat soaked intercooler will not perform well, and spraying water while moving will remove excess heat from it, so a difference can be felt. Go ahead and tune those IC settings with ecuflash, you will help your car a lot more.
About that light you mentioned, I also wanted to have something that let's me know when the system sprays, I though about installed a led to the pump wires, so whenever the pump gets current, so would the led, I could install the led next to the IC button and I would know when it is actually spraying. I might tackle that project someday
Old Jul 23, 2012 | 12:02 PM
lracer28's Avatar
Mine is deleted, no codes!
Old Jul 23, 2012 | 02:52 PM
barneyb's Avatar
Yeah, I guess I should set it to spray on knock. If the car behind me has his wipers on I'll know I have a problem.
Old Jul 23, 2012 | 04:11 PM
RoMeIX's Avatar
Removing it will not cause any type of CEL or anything. It will be fine.
Old Jul 24, 2012 | 08:58 AM
DogEater_619's Avatar
Mine does't work either so i decided to removed it......... plus i removed the air duct too..... it looks cleaner.........
Old Jul 24, 2012 | 09:37 AM
deadstockkpomp's Avatar
so removing the duct wont mean anything i dont track or even daily drive my car
Old Aug 11, 2012 | 05:49 PM
EvoIIIAj's Avatar
Removed mine today, this thing is huge lol!
Old Aug 11, 2012 | 10:56 PM
batty200's Avatar
Downgrading cars! Awesome! I might just remove my intercooler and turbo as well. The car will weigh less too! It will look cleaner under the good without all those turbo pipes and Hose's and other garbage!
Old Aug 12, 2012 | 11:05 AM
Craig King's Avatar
Any idea how much the whole IC sprayer system weighs once removed?
Old Aug 12, 2012 | 11:18 AM
gsrboi80's Avatar
Not sure if serious??
LiX
May 28, 2013 05:36 PM
XtremEvo9
Jun 16, 2007 07:48 AM
evo81
19
Sep 18, 2005 01:58 PM
outsider
Jun 7, 2004 09:52 AM
STC
15
Mar 31, 2003 07:39 PM
