Reverse Light Issue
Update - 8/17/13 - I've decided to take another swing at this, living without reverse lights is getting old quick. Where can I find connections C-124 / C-23?
So, bottom line up front -
Out of ideas. I have the wiring diagram available to me and it is spartan to say the least. It's on
page 90-63
I have my voltmeter handy, what should plug B-111 (Backup light switch plug) read when I insert the +/- leads into it? I figure this is the logical place to start as early into the food chain as possible.
*I just realized I am mentally challenged. Red --> Brown at B-111 are both hot lines and not ground, hungry brain completely forgot the switch completes the circuit....the hell is wrong with me :-/
- Reverse lights didn't work (not turning on)
- Replaced bulbs. Nothing.
- Replaced Fuse. Nothing
- Replaced Transmission Switch. Nothing.
page 90-63
- Reading at C-211 (7.5A Fuse) - 12.2V - OK
- Reading at B-111 (Backup Light Switch) - 13.7V - CAVEAT
- Reading at F-14 (Backup Light) -
Have you cheacked for power and ground at the revs lights. Not going to get a reading if switch is unplug unless your doing an ohm test to see if you have a open in the wires, you should a a 10- 12v at the backup lights
) ).I'm not getting a reading at F-14 with everything else connected (B-111 Is jumped) which leaves me open to the caveat at the end of OP.
Have you tryed ground the lights see if you have a bad ground you should have 12v at 6 with the voltmeter put one lead on 6 and one lead on a good ground if you read 12v you have a ground problem. Have you tried swaping relays see if that helps
I'll check point 6@F-14 after dinner. I'm not seeing a relay on the diagram, could you be more specific?
Ya, I had a positive reading at the fuse and a positive reading down the line at the actual switch plug ONLY if I ground it to the (-) battery terminal.
[quote=dr_latino999;10290746]So, bottom line up front -
Looking at this schematic I would assume that the side of the connector going to the switch would ring continuity or have close to zero Ohms resistance if the car is placed in reverse; or an infinite (or extremely large ) resistance with the transmission in any other position and not ring continuity. If this is to basic an answer sorry.
[QUOTE=dizaryl;10292101]
Oh you're right, I just appended my OP to state I am officially retarded and the brown and red at B-111 are both hot and the switch is just that - a switch. All my key readings need to be done at the tail now.
