Clutch Issues
Old Jul 22, 2012 | 03:50 PM
Addictuned Evo's Avatar
Clutch Issues
Hi,
After doing a search, I cant find anyone else with the same situation. I have a 2005 Evo viii with 51,000 miles. The check engine light came on the other day and is coding out with "clutch performance". The clutch is less than 10,000 miles new. It grabs fine and does not slip a bit. What I have noticed is that the clutch pedal does not recoil back up all the way and I find myself pulling up on it with my foot. After that, the pressure grabs alot sooner. Does anyone know why this is and how do I fix the code. I already tried clearing it but the code came back.
Thanks for any help.
Addictuned Evo
Old Jul 22, 2012 | 03:52 PM
kaonashi's Avatar
Originally Posted by Addictuned Evo
Hi,
Addictuned Evo
Post the code, Have you tried bleeding the slave? also is it the OEM clutch? My slave cyl went out on my 03 @ 43k miles
Old Jul 22, 2012 | 04:28 PM
Ill hook the scanner to it at work tomorrow and get the code. The clutch is an ACT clutch with flywheel.
Old Jul 22, 2012 | 05:20 PM
4RETECH's Avatar
Try bleeding the slave cylinder.
My slave is the original one.... Only ones I ever see fail were cars that sat for a while.
Old Jul 23, 2012 | 05:39 PM
Ill give that a shot this weekend. I was too busy today to scan the car for the code number. Thanks for the help.
