Idle issue
Idle issue
Alright guys need some help, my 8 has some work donr, has 272 amoung other goodies, was tuned with speed density running fine and now when I get on it and then come to a stop it won't idle correctly, it will rev high almost 2-3k rpm thn come back down and Then back up like I have a bad iac? Yet reading other posts ppl have spoken about just being iac sensor so I'm confused, basically how can I tell what's bad weather it's a bad iac or just the iac sensor? Thanks in advance for any helpful information
All hoses good, only seems to happen when sitting in neutral or with clutch down... Just came across another thread in which they had very similar issues and replaced iac ironically from a Chrysler Sebring , which is same part ( referencing thread by 4retech)... I'm still learning about cars, idk of my throttle body is catching? It drives fine until I come to a stop or also on cold start sits very high at like 3-3200k then drop backdown then up again
i have the same problem..i changed my TPS and IAC in addition to converting my BOV to recirc.but that didn't solve the problem..i was told to change o2 sensor it could be the problem..
so i suggest you should just find a used parts dealer to check which one of those is gone bad???
