installing o2 housing
Old Jul 26, 2012 | 03:36 PM
Rawger's Avatar
Hey everyone I'm installing a megan o2 housing on my evo 9 this weekend and was wondering what kind of issues would I be running into cuz I heard on the 8-9 its very common for the bolts to snap wile taking the oem off. So any heads up advise will be great thanks
Old Jul 26, 2012 | 03:39 PM
meckert's Avatar
PB blaster the night before on everything. re-apply more then once.
Old Jul 26, 2012 | 04:43 PM
03evo_joe's Avatar
never changed mine but if bolts are breaking then heat will be your best friend
Old Jul 26, 2012 | 05:11 PM
dr_latino999's Avatar
Veteran: Army
I'm pulling my manifold off this weekend and I've started my PB regimen early
Old Jul 26, 2012 | 05:16 PM
white8's Avatar
Heat the housing around the bolts trying not to heat the bolts and pb the **** out of them.
Old Jul 26, 2012 | 06:14 PM
sincitydagzr's Avatar
be sure to pb the o2 sensor and don't strip the bolt on it like i did.
Old Jul 26, 2012 | 06:19 PM
Lexus01IS's Avatar
You are going to have lot of fun doing it. I sure did
PB and lot of patience.
Old Jul 26, 2012 | 07:22 PM
svt_lightning01's Avatar
I just finished my o2 dump last night. Broke one bolt. I would advise a lot of pb ad a decent breaker bar and some prayers for no broken bolts but they are .50 cents at hardware store so no biggie if so lol. I went the radiator route gave me a lot of room and I didn't worry about torquing the exhaust manifold back. Set back 3-4 hours or more of first time. Good luck bro.
Old Jul 26, 2012 | 08:37 PM
MyronGainz's Avatar
Did you get stainless steel bolts at that price? Anything less than that won't do a very good job of holding up to the heat of the turbo
Old Jul 26, 2012 | 08:46 PM
Two two bolts I got were for the downpipe. I've taken it out so many times one finally gave so I changed them both. Grade 8 bolts stainless. My buddy helped me out so he may have marked them down lol idk he didn't say. Either way it isn't gonna break the bank
Old Jul 26, 2012 | 08:50 PM
Rawger's Avatar
I was going to torch the bolts but didn't think of pb so ill do that for sure, and should I use stock bolts if they don't snap or buy some stainless. Thanks everyone so far for the advise lol
Old Jul 26, 2012 | 09:12 PM
Well I had some trouble with the o2 sensor I ended up have to remove the old o2 housing and torch it to get the sensor out lol pita
Old Jul 27, 2012 | 12:54 AM
Rawger's Avatar
Also are all the gaskets and doughnut gonna work fine when I put this in or should I get all new ones
Old Jul 28, 2012 | 04:28 PM
Veteran: Army
I spent 40 dollars on a good map torch. Found out a new sensor was 57 dollars. New sensor here I come.
Old Jul 28, 2012 | 08:47 PM
The new oem front o2 isn't $57? A universal may be I think the Bosch is in that range
