Constant Vibration
Old Jul 27, 2012 | 12:08 PM
1illrican's Avatar
Constant Vibration
Hello all,
I have a constant vibration throughout the entire car that's driving me crazy. It happens while idling & gets worse once you put it in gear & get high into the RPM's. When its nice out its not as bad as when it rains. Once its really wet out the vibration gets a lot worse & resonates throughout the entire cabin even at low RPM's.
Any ideas???
Old Jul 27, 2012 | 12:11 PM
RoMeIX's Avatar
Is the only symptom the vibration? Are there any noises? Any check engine lights etc...
Old Jul 27, 2012 | 12:15 PM
1illrican's Avatar
No lights & the car feels fine. I did have 2 recently but they were completely unrelated. About 3 months ago my front O2 sensor went & 2 days ago one of the EGR vacuum hoses behind the throttle body popprd off. Fixed both times & light went away. No other codes thrown.
Revs do seem to hang a bit the higher I rev but I don't think that has anything to do with the vibration.
Old Jul 27, 2012 | 12:26 PM
EdSales's Avatar
Do you have aftermarket motor mounts? When you shift at high rpm, do you feel the car kinda rock forward and back, or any clunking noises?
Old Jul 27, 2012 | 12:29 PM
1illrican's Avatar
I did change the front mount but the vibration started a few months after I installed it.
Old Jul 27, 2012 | 12:35 PM
EdSales's Avatar
Try shaking the motor back and forth with your hands while looking down at the engine bay. Make sure all the bolts are still in the mount/cross member. I have had bolts shake lose before from not tightening enough.
Old Jul 27, 2012 | 12:40 PM
1illrican's Avatar
ok, I will gove that a shot. Any other suggestions? I kind of feel like it could be caused by the exhaust. I don't have a jack anymore & am going to go to a friends house this weekend & get under the car.
Old Jul 27, 2012 | 12:46 PM
EdSales's Avatar
I don't know about exhaust. I broke a hanger once unloading off a trailer in one of my Civic's before. Anytime you sat in the car you could hear it sqeak as it shifted. I guess you could grab your exhaust from the rear and give it a shake. Only real way I see the exhaust causing a vibration is if it rubbed against the car.
Old Jul 27, 2012 | 05:42 PM
MRolla's Avatar
Check your drive shaft carrier Bearing
Old Jul 27, 2012 | 06:06 PM
novem's Avatar
Unload your suspension, you should be able to narrow it down.
N
Old Jul 28, 2012 | 11:20 AM
1illrican's Avatar
Would that cause vibration in neutral?
Old Jul 28, 2012 | 11:21 AM
1illrican's Avatar
N
What do you mean, get the car in the air? I don't see how that helps since the car vibrates even when parked in neutral idling.
Old Jul 30, 2012 | 12:51 PM
1illrican's Avatar
Bump
Old Jul 30, 2012 | 12:59 PM
pignosesr's Avatar
Probably not too much of help but my old exhaust hangers were worn out and would clink against my drive shaft. When it was nicer out it wouldn't do it as much, but as soon as it rained it got super bad. It wasn't so much a vibration more of a grinding
Old Jul 31, 2012 | 07:58 AM
1illrican's Avatar
I feel like its exhaust related but I just haven't had a chance to get the car in the air yet. Regardless I think it has to be something under the car causing the vibration.
