Constant Vibration
Old Aug 1, 2012 | 07:21 AM
1illrican's Avatar
Bump
Old Aug 1, 2012 | 04:32 PM
dr_latino999's Avatar
Veteran: Army
Any luck? I'm running into a similar issue and am ready to retire this car off a cliff - maybe we are on the same boat.
Old Aug 1, 2012 | 07:27 PM
Stock-ish's Avatar
i may be worth while to get the car on a lift. you got bad rubber somewhere, or you have your exhaust resting against the body. check em one by one.
i hardly notice this in my car, with poly mounts and no balance shafts..
my steering wheel shakes alot.
Old Aug 2, 2012 | 07:18 AM
1illrican's Avatar
Nothing yet. I was supposed to get the car up in the air this past weekend but the weather didn't cooperate.
Old Aug 3, 2012 | 07:45 AM
1illrican's Avatar
What do you mean by "bad rubber"?
Old Aug 3, 2012 | 08:26 AM
Veteran: Army
I found my culprit, balance shaft belt had stripped
Old Aug 3, 2012 | 08:30 AM
1illrican's Avatar
Ok, I'm in need of the 60k service so I will be replacing all the belts soon. I will give this a look tonight.
Old Aug 5, 2012 | 06:55 PM
Stock-ish's Avatar
you may wanna look into the balance shaft elimination kit, not as smooth but better for the motor over all.
Old Aug 6, 2012 | 07:12 AM
1illrican's Avatar
So since I will be doing the 60k service will it be easier to do the balance shaft elimination at that time? I haven't really looked into it so I'm not sure how complex it is.
Old Aug 6, 2012 | 08:56 AM
evodriver49's Avatar
sounds like your exhaust rubbing against the drive shaft. consider a hammer and some noise
lznk41
17
May 2, 2020 07:18 AM
Olms2468
May 14, 2015 05:48 AM
TommiM
15
Sep 30, 2014 04:46 PM
ArtofRalli
Oct 20, 2011 01:21 PM
knightey
Sep 19, 2011 10:22 AM
