Bad Vibrations
Old Oct 17, 2011 | 05:13 PM
ArtofRalli's Avatar
Bad Vibrations
I seem to be having vibrations through the steering wheel and pedal (alot) when decelerating. The car literally vibrates. Its been getting worse over a period of 2 months.
I have 34,000 km's on the car.
I have original tires (really low tread)
Original tranny fluid (getting changed Thusday)
The only reason Im listing these is because as the tires and tranny fluid became more worn, the vibrations got worse. Could there be a link?
Old Oct 17, 2011 | 06:16 PM
AntiBlitz's Avatar
you need to explain what the vibrations feel like, at what speed they occur, and do they come and go or every time.
Does it feel like when you break too heavily and the car shakes furiously?, or is it like a tire balance issue shake? is it a lurch forward? Or could it be your exhaust drone?
between what speeds?
is it everytime, once in a while? car warm or cold?
Old Oct 17, 2011 | 08:08 PM
petro's Avatar
I'd be willing to bet it is the tires if your tread is really worn (like you stated it is). My GF's Mazda 3's tires are worn and it sounds and feels like I'm operating a jet when in motion.
Old Oct 17, 2011 | 08:50 PM
gaabbee's Avatar
Get new tires...as the tires wear down it can unbalence the wheel. Give it a try you need them anyway with winter coming soon
Old Oct 17, 2011 | 08:53 PM
ArtofRalli's Avatar
Your right i needed to state more info.
The vibration happens on acceleration and deceleration.
Deceleration is bad between 90-120km
This is only seems to happen when im moderately hitting gas (2-4k rpm)
NO vibrations under 2k rpm and over 4.5k rpm.
EDIT FROM ABOVE STATEMENT : When I go full out there are no vibrations. (above 4.5k rpm)
Vibrations happen cold OR warm.
Does NOT happen if i break to hard, thats different with these tiny brakes haha (car shakes lol)
Its everytime.
I do have a UR catback, BUT i have never encountered a vibration like this. It SEEMS like it comes from right beneath the gearbox area. The pedal, steering wheel are all effected.
The tires are original with 34,000km on them. I starting to believe thats the issue.
Old Oct 17, 2011 | 08:54 PM
ArtofRalli's Avatar
Can unbalanced OR really worn down tires create such dramatic vibrations?
Old Oct 17, 2011 | 09:18 PM
AntiBlitz's Avatar
yes, have you been rotating them, or had the car lowered?
Old Oct 17, 2011 | 09:42 PM
ArtofRalli's Avatar
the tires were rotated twice. The tread is very very low. Im guessing thats the problem. New tires is next! I actually was on youtube and the exact symptoms i was expla low tining is due tread or unbalanced tires.
Old Oct 18, 2011 | 01:30 AM
user 7082023424's Avatar
Every get the alignment checked? Bad toe in can cause a vibration. Tyres can collapse on the inside too - no visible damage until you take if off the rim.
Old Oct 18, 2011 | 05:53 AM
gaabbee's Avatar
I say tires...if that doesn't fix it tighten the exhaust again. I had my car have really bad vibrations and it turned out that the lug nuts on one of my wheels were coming undone. It was only at certain rpms which made it hard to figure out.
Old Oct 18, 2011 | 04:23 PM
ArtofRalli's Avatar
Ok, so i took the car to my cousins garage and there is a large rattle coming from the exhaust, catalytic concerter to be exact.
Everytime you shake or hit (gently) the exhaust theres a rattle that comes from right where the cat is.
We checked all heat shields, rotated the tires, tighted all the bolts and checked all the exhaust hangers and the only rattle is the cat.
ENOUGH to make large vibrations in the cabin?
Old Oct 20, 2011 | 01:21 PM
majinfajita's Avatar
That's all I needed to read.
This is a very common issue and it's just the inherent driveline vibration in this car and there are numerous posts on this.
Easy way to replicate -- be in fifth gear, between 2000 and 2400 rpm, and let off the gas. Below 2000rpm you won't feel it, above 2400rpm, you won't feel it.
The solution -- don't engine brake in 5th between 2000 and 2500 rpm. I'm not trying to be a dick, that's really the solution. You really won't notice it in automatic, but in manual you do. There's a reason I ride 4th gear much higher in everyday cruising (I used to shift into 5th at 60km/h, now I take it to 67-70km/h) and downshift to 4th much sooner than I used to.
ralliart425
21
Apr 9, 2017 08:57 AM
girth5785
Jul 27, 2016 08:27 AM
aldoevo
Jun 24, 2013 11:04 PM
Evo a Mula
Aug 20, 2009 05:39 AM
spudlus
Dec 20, 2006 10:51 AM
