Cams help??d
Old Jul 28, 2012 | 10:20 PM
lostsoulsevo's Avatar
Originally Posted by AEvans190
the problem I am having is when I rotated the cams to TDC, I don't know if I went clockwise or counter-clock wise....
you can turn the cams which ever way you want if the belt is off
Old Jul 28, 2012 | 10:22 PM
here is a cam install, follow these steps and youll be good to go
http://www.evomoto.com/tech_info.php?tech_id=18
Old Jul 28, 2012 | 10:26 PM
AEvans190's Avatar
Originally Posted by lostsoulsevo
i'm sorry bro, its hard for me to help you understand. if your head is timed with the timing marks on the valve cover, good. you need to take off the lower timing cover, but before you do this. turn the crankshaft clockwise till the timing marks on the crankshaft pulley are lined up with the "T" on the lower timing cover. after this you need to take off the lower timing cover. now place the belt on starting with cam gears and work you way clockwise lining up all the pulleys with their respective timing marks. you also need to do this with your balance belt before you work on the timing belt. i'm gona trying and find a evo site with pics
Thanks man I really appreciate your time.
A pic might help me better understand... Right now I have everything disassembled (lower cover, etc) to get to the timing belt
Old Jul 28, 2012 | 10:32 PM
you can also download this service manual for help
http://www.evoscan.com/vehicle-manuals
Old Jul 28, 2012 | 10:33 PM
steven121's Avatar
how can you tell what cams you have? I have cams on mine but when i bought my evo it came with them? got it from a dealer who got it from an auction
AEvans190's Avatar
I guess a better title to this post would be timing belt help. I am not doing a cams installation. I just messed up the timing...
Old Jul 28, 2012 | 10:48 PM
i'm cofused now? i was under the impression your belt was already off? was the belt not off?
Old Jul 28, 2012 | 11:40 PM
AEvans190's Avatar
yes that is correct timing belt is off, balance belt is on.
Old Jul 29, 2012 | 12:20 AM
AEvans190's Avatar
The crankshaft pulley is where I am getting confused. I have to remove that pulley before I take the lower cover off.
There are two crankshaft sprockets right? one for the balance belt and the other for the timing belt. How do I make sure the crankshaft pulley is timed right? That pulley has been off since the beginning...
Old Jul 29, 2012 | 01:37 AM
LOL you're thinking to hard brotha! yes there is a sprocket. like i said before make sure the crankshaft pulley "notch" is pointing to the "T" on the timing cover. the sprocket should be putting towards the right, you will see a notch in the block where it lines up with. if you read the attached service manual link you'll know what i'm talking about
