First boost leak test atempt
Old Aug 2, 2012 | 08:02 AM
17579EVO9MR's Avatar
I tried my first boost leak test last night and I am a little confused, unsure I did it right! I went through the diy guides built my own terster and began. I pulled the fuse for the double pumper, pulled the manual boost controller line going to the wastegate. I found two leak right away, at 20 psi. Fixed them and all was good there. But the car would not go above 20 psi. I was using a tire/ electric ball pump, through a valve stem. I know pressure was building because the tester blew off. I know the best way is with an air system but I do not have one yet. Is there anything else im supposed to unplug, or unhook? My e85 tune is good tuned to 40 psi, and I'm only getting to 20 psi. I do not hear any leaks, that would cause it to not build the pressure. Can any one help me out here with advice? Thanks
Old Aug 2, 2012 | 02:05 PM
Anyone?
Old Aug 2, 2012 | 02:12 PM
batty200's Avatar
Your bike pump might not be able to make more pressure than that on such a large volume. It is good if you are able to get you boost gauge to 20psi.
tommyb123
May 29, 2015 10:36 AM
fireroasted
Nov 30, 2014 01:39 PM
CBRD
39
Feb 9, 2012 09:53 AM
Clipse3GT
18
Dec 16, 2009 02:48 PM
